no washer fluid
So for the past few months I have been wtihout the ability to use washer fluid. It does not come out of the rear wiper nor the front wiper. My question is, are both the pumps broken or could it be something else. I do have washer fluid in the truck and it's full. It's a '95 Blazer.
Re: no washer fluid
blazergirl25 First things First,
Do you have power going to the windshield washer motors, Can you hear the motor run when you activate them?????
1998 BLAZER LS Vin-W 4Dr 2wd 2004 Cavalier LS 4Dr 2.2 Ecotec "Good Part's ain't Cheap--Cheap Parts ain't Good" |
Re: no washer fluid
No, there is no sound when trying to use the washer fluid.
Re: no washer fluid
You will need to get an electrical tester on the power wire going in to the washer bottle, Then activate the washer and see if you have power to it, This test will find out if the motor(s) are good or bad if there is power in it. No power in the wire may mean a broken wire somewhere? You can also try Jumping the washer motor with a 12v jumper wire....
Re: no washer fluid
Separate little pumps for each - pull the air filter box and you can get to them. About $15.
