Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 10-15-2006, 12:20 AM
jasonw75 jasonw75 is offline
Headlights don't work
I investigated a problem in which my tail lights would not illuminate, and eventually discovered that a yellow relay on the drivers side of the trunk, hidden behind the trunk liner near the trunk hinge was at fault.
I replaced it, and discovered that my headlights no longer worked. At first, I thought the new relay might be the problem, but I don't think that this particular relay has anything to do with the headlight circuit.
One clue is that, though both the normal and high beam positions on the switch give no love, if I hold the headlight switch in the "flash high beam" position, then the high beam lamps work (rather inconvenient, not too safe, and definitely impolite to drive this way!).
Could it be the relay (I doubt it, since I don't think that relay is related to the headlights)?
How about the headlight switch (unlikely, since it worked perfectly right before my relay-replacement project)?
What about one or more fuses and/or relays? This seems most likely, but I'm not an expert. There are so many fuse and relay panels all over the car, in illogical places. There are only so many things it could be, especially given the clue that the flash high beam function works.
Please help!
Thanks!
Jason Wren
Denver, CO
Old 10-15-2006, 02:40 AM
KimMG KimMG is offline
AF - Advisor
Re: Headlights don't work
Possible causes
fuses
high-beam switch
headlight switch
headlight relay
The flash to pass feature will work with headlights off, whereas the high-beams won't. So don't discount it because it has to power inputs for the lights.
Use a wiring diagram, and a test light or meter to test to see where you have voltage.
Old 10-15-2006, 09:04 AM
KimMG,
Thank you so much for your imput. Do you know where I can easily find a wiring diagram for this car (perhaps one that isolates the headlight circuit)?
Thanks again!
Jason Wren
Old 10-15-2006, 02:42 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Try this: http://www.autozone.com/servlet/UiBr...3d80140920.jsp It appears fig 17 and 22 apply. Also you might get some info from the FAQ and manuals section at the top of the forum.
Old 10-08-2009, 11:02 AM
Daryl14 Daryl14 is offline
I realize this is an old post but did you ever find a resolution to this problem? I'm having a similar situation. I have a 97 Camry. The headlights will work on high beam but not low beam. When they are on high beam, the high beam indicate is NOT lit on the dash. Any ideas?
Old 10-08-2009, 11:18 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Check the headlight number and make sure the correct headlights are installed. Make sure they are connected correctly.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
