Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 10-15-2006, 12:00 AM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
Talking Ls Vtec or B20Vtec?
Which motor between a Ls Vtec or B20 Vtec would be a better to have as an upgrade?
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 10-15-2006, 12:31 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: Ls Vtec or B20Vtec?
it depends on what you're going to use it for and what kind of work you're going to do to it...
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 10-15-2006, 01:01 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
I've read (aka no personal knowledge) that it's harder to resleeve a B20, because there isn't enough material for the sleeves to grab onto the bottom of the block (don't know the technical name for that part). So I'd say go LS/vtec. You could always bore it out 3mm if you resleeve it, and you'll have a stronger B20.
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
you have to decide what you need it for. once you foigure that out then you have answered your own question. wow that was easy.
-tony-
2000 honda s2000
Old 10-15-2006, 03:24 PM
Schister66's Avatar
AF -Advisor
you can get B20's resleeved out to an 89mm bore....that being said, i would much rather use an LS block because to sleeve and bore a B20 out to 89mm takes a lot of room inside the engine bore. There isn't a lot of sleeve material left at that point. If you're going to boost, this isn't the way you want to go. The only real application this has is in an NA car where you dont have to worry about ridiculous cylinder pressure.
B20 sleeved and bored to 89mm if you're going NA
LS sleeved and bored to an 83-84mm if you're boosting
----all of this provided you have the money to do that-----
Old 10-15-2006, 03:42 PM
00accord44's Avatar
00accord44 00accord44 is offline
High on Potenuse
Send a message via AIM to 00accord44 Send a message via MSN to 00accord44 Send a message via Yahoo to 00accord44
Your HB is gonna be the recipient of this new engine?
ECNATSISER AL AVIV
Old 10-15-2006, 05:23 PM
Schister66's Avatar
AF -Advisor
personally i think an EF would be best with the NA 14:1 89mm NA B20VTEC That would be a badass car...you could hit high 200's with that setup...I've seen a 15:1 86.5mm GSR with a wickedly ported head make just shy of 300whp...thats impressive for a streetable car!
Old 10-15-2006, 05:30 PM
00accord44's Avatar
High on Potenuse
^I agree. The B20 definitely has potential to be a beast. My friend in florida built a Rex with a B20 vtec hitting mid-low 13s last I went with him to the track and I know he's not done with it. That thing moves pavement big time.
ECNATSISER AL AVIV
Old 10-15-2006, 06:46 PM
Schister66's Avatar
AF -Advisor
do that...or get a K swap....
i found a perfect K series EG for sale on Honda-tech....its a mint EG and the engine is strong. The guy wants $9k for the car...anyone want a GSR Turbo?
Old 10-15-2006, 09:58 PM
Jos4DCivic's Avatar
all i want to do is have it N/A ,port and polish with a good tranny
91 Hatch SI
Finally painted!!!
Old 10-15-2006, 10:35 PM
Schister66's Avatar
AF -Advisor
idk then....are you planning to sleeve?? I would just rock either one....whatever fits your budget better
Old 10-16-2006, 02:23 AM
then go with the b20. you'll get more torque. get a short geared tranny preferably a ys1(the best in my opinion)
-tony-
2000 honda s2000
Old 10-16-2006, 07:13 AM
Schister66's Avatar
AF -Advisor
B20 VTEC w/ a YS1 tranny,.....if you can afford it, get some higher comp. pistons and build the B20 a little...
Old 11-20-2006, 11:41 PM
des7165 des7165 is offline
Send a message via AIM to des7165 Send a message via Yahoo to des7165
I would say go with the b18 and put a b16 head, this is waht im planning on doing. I'm low on cash so im gonna swap the ls in and then buy the b16 parts plus cams piston and all the good stuff then get all the head work done at the same time. After that i should be around 200hp if not over so i would say thats the way to go plus its cheaper.
94 hatch
Old 11-22-2006, 06:07 PM
S13wanabe's Avatar
S13wanabe S13wanabe is offline
Tolerances are extremely tight on a B20/Vtec. If you do go this route, you need to have a reputable Honda guy build it. The LS/Vtec is better in my opinion just for the reliability reasons. The B20/Vtec would have good torque though. I would do an H22 over a B20 if torque is your desire. H22 are cheap and despite what people say, they are not much heavier than a b-series motor. They just sit in the engine bay at a different angle. For drag racing, H22 rip. But like I said, the LS/Vtec is the best bet in my eyes. Plus I have one that makes over 200whp.
