Old 10-14-2006, 11:37 PM
1991HB 1991HB is offline
Send a message via AIM to 1991HB
heat hand--very strange
I was out tonight driving around and on my way home I noticed that my heat hand would drop all the way down and then back up to normal position. It did it quite a few times but it never once went up like it was over heating. This is the first time I have ever noticed it doing this and there is no check engine light either. If you need to know it's a '91 hb with a d15 block and y8 head. Any Ideas? Thanks
Old 10-15-2006, 01:54 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: heat hand--very strange
Thermostat could be getting stuck open.
Old 10-15-2006, 01:03 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Could also be your temp gauge sensor or loose wire. Is there any corresponding fluctuation in the heat output available from the heater when the gauge is moving? In that case I'd def go with TSC and check the thermostat. GL
