Old 10-14-2006, 10:47 PM
98 headache 4.3 98 headache 4.3 is offline
warm engine hard starting
1998 Blazer 4.3 Vortec when engine is cold it starts right up, when engine is warm it will not start. I will crank the motor many times and then I must push the gas and make it start. The engine runs smooth with no miss but it gets very poor gas mileage. I have the CSFI fuel injection--you might know it as the "Spider Injection". One mechanic told me they sell a modified fuel injection from the dealer. Is this my problem. It is very costly. HELP!!! My pockets are getting very thin.
Old 10-18-2006, 06:27 PM
sreve sreve is offline
Re: warm engine hard starting
no check eng light? a scan looking at data stream would be a good start. how cold? coolant sensor is a possibilty.
Old 10-18-2006, 07:26 PM
rhandwor rhandwor is offline
I would remove the ignition module and have it checked free at auto zone or advance. Take a hair dryer with you and warm it up before testing. I would ohm your temperature sender and ask to ohm a new one at the store. A big difference in reading I would change. If you have a logic probe that will monitor pulse I would check around the module and hall effect sensors and signals to the coil. If you can find coil neg. put a 12V test light on it and see if it blinks when hot.
Old 11-03-2006, 10:20 PM
Thanks for getting back to me. I shooting for the new MFI from the dealer $300 clams. I hope it works
