Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 10-14-2006, 05:47 PM
D4rk3y35 D4rk3y35 is offline
VSS - Vehicle Speed Sensor
A little background.
1994 Honda Passport 3.2L V6 Auto
The speedo quit working about a week ago.
Today the Check Engine Light comes on.
I ran the codes and got 24 Vehicle Speed Sensor - No input signal.
Tested it Per Haynes Manual and its bad.
I don't have 199.99 for a new one. So I'll be going to a junkyard to get one.
Now my question.
Should i be able to get this part off any 4X4 Isuzu Rodeo, Honda Passport 2.3L, 3.1L or 3.2L Pre 1996? Bascily any OBD-I vehicle?
Any advice would be appreated..
I'm also going to need a power steering pump.
Thanks
Old 11-19-2006, 01:06 PM
ECMgarrett ECMgarrett is offline
Re: VSS - Vehicle Speed Sensor
I HAVE THE SAME ISSUE! i have never gotten it checked though, so I guess thats what the problem is, il need to look into this
Xfighting the war on drugs a 1/4 mile at a timeX
93 mr2 turbo
94 rodeo
99 buell s3
76 HD shovelhead
Old 11-20-2006, 11:28 AM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
most common thing on these vss issues
worn speedo pinion gear
remove the speed sensor look at the plastic gear there may be worn teeth
on the gear if so you can rep[lace just the gear
Old 03-04-2009, 03:59 AM
Stella34 Stella34 is offline
Send a message via MSN to Stella34
There are two types of senders, one has a lead about 5" long with a plug on the end
and the other has no lead.
The plugs are different.
Be gentle when removing the plug from another vehicle, the sensor likes to break just under the wire plug...
Old 07-31-2009, 08:06 PM
sing57 sing57 is offline
what is the difference between a 2wd and 4wd speed sensor. Will the 2wd work on the 4wd. This is on a 1996 passport
