Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 10-14-2006, 01:39 PM
bigrod118's Avatar
bigrod118 bigrod118 is offline
99 oil pan gasket replacement
My buddy came over today to have me help him replace his oil pan gasket on his 99 Honda civic (no badging on the car) I was wondering what the torque spec was for the oil pan bolts, his stupid ass forgot the Haynes manual.
thanks for any help.
EDIT: ok, I just took a look at it, and it appears that I would have to take off parts of the trannsmission housing to get to some of the pan bolts. Is there any trick to get around this? Has anyone ever done this that can lend some 1st hand experience?
Old 10-14-2006, 11:15 PM
bluevp00's Avatar
bluevp00 bluevp00 is offline
Re: 99 oil pan gasket replacement
The torque spec is 104 Inches-lbs (according to Haynes).
I think you just have to remove the small bracket thats between the transmission and the oil pan, not a hard thing to do, and the trans doesn't need any added support underneath while it's off. I had mine done by a shop & it only took about 1 hour to do (including oil change & RTV drying time) so it doesn't seem to be too hard to do. Good luck.
Old 10-14-2006, 11:38 PM
bigrod118's Avatar
Yeah, I noticed the bracket and some exhaust had to be taken off, that's not what really bothered me, but where that braket connects to the tranny, the oil pan overhangs about 1.5 inches on top of the tranny, and I still wouldn't have had access to i'm guessing about 5-6 bolts.
I really wish I would have tried to take a picture while Iw as under there. If we decide to look at it again instead of him just taking it to a shop, I will definitly take a picture of it, I just can't beleive they would design it so that you have to take off 1/4 - 1/2 of the trannsmission casing just to take off the oil pan.
Thanks for the spec tho, if I decide to try to tackle this for him it will come in handy.
Old 08-09-2013, 02:48 PM
JayStarr22 JayStarr22 is offline
I just finished doing this job and was pleasantly surprised by how easy it eventually turned out. you do have to remove the exhaust from the headers to the cat. and two pieces that for some reason Honda deemed necessary to put in your way.
You must remove both the aluminum bracket and the tranny face cover in order to access all the oil pan bolts.
You do not need to support the transmission. Although i did, and then realized its still bolted to the engine.
