Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-14-2006, 07:37 AM
genegr genegr is offline
Check Engine light
On my 91 GT 5.0 the CEL comes on during acceleration then off when I let up to shift. It will not come on if your just sitting and rev up the engine so it's bin hard to test with the code reader. I replaced the four vaccum lines at the rear of the passenger side engine compartment. Spark plugs look a little white. thanks for any ideas. 118,000 miles to date
Old 10-14-2006, 09:40 PM
mustangmike351c mustangmike351c is offline
Re: Check Engine light
my be going lean under acceleration. check fuel filter
Old 10-15-2006, 08:24 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
What gas are you using? 87,90,91,93?
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 10-15-2006, 08:38 AM
Been using 87 octane, I have a full tank and it takes me a month to use that, should I try an octane booster? Looking at the fuel filter it looks to be original, I will get that changed ASAP. thanks
Old 10-15-2006, 11:05 AM
SkylineUSA's Avatar
It akes a full month to use a tank, go open her up on a good run, and see iuf the does anything
Just a shot in the dark, run some 93 when you get a chance, see if things change then as well.
Old 10-15-2006, 10:06 PM
KimMG KimMG is offline
AF - Advisor
Check to see if there are any stored codes. It is best to find out why the light is coming on instead of guessing.
Old 10-19-2006, 08:44 PM
thanks, tried the STP octane booster and new fuel filter, no change. I'm trying to find someone in the twin cities with a drive on dyno. The local shop didn't find any stored codes but he thought the dealers may have a better code reader then his.
Old 10-22-2006, 01:02 AM
dorfboy dorfboy is offline
Send a message via ICQ to dorfboy Send a message via Yahoo to dorfboy
Before all that, try the upgrade in octane and change out your CO2 sensors. You may be getting a slow response from either one or both. Since it takes a month for you to blow through a tank of gas, you might have some junk in your tank.
Old 10-22-2006, 09:44 AM
It was 39 deg outside temp yesterday when I took it for a ride. The light didn't come on till the engine was about 165 deg, then would come on during acceleration. The light would stay on above 75 mph even when I lifted till I was below 75. I ran the tank down to 1/4 full then filled with 92 octane with no change on the ride home. I didn't mention earlier that the low fluid light is on all the time, could this be the germlin that I'm chasing? thanks
Old 10-25-2006, 10:55 PM
do you have any exhaust or vacuum leaks? if you can put a scanner on it I bet the light comes on because of an O2 senor is reading lean. you should have codes stored any time the cel comes on.
Old 10-27-2006, 09:24 AM
reekor reekor is offline
I would clean the MAF sensor, and even more so if you have a oil charged air filter in the car (K&N).
After reading all of this, I just can't help but think that it's EGR related. I would remove the EGR valve and make sure the that EGR channel is clean and that the EGR valve is working. Then I would check the EGR vacuum regulator and clean the foam filter in it. If that all turnes out to be fine I would replace the EGR Valve Position (EVP) Sensor.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 10-27-2006, 02:13 PM
AF - Advisor
Low fluid light? Problems can compound. What fluid is/was low and have you corrected this? What are the codes you are getting from the CEL? White spark plugs are indicative of running lean. Is the O2 sensor working properly?
Old 11-19-2006, 06:37 PM
Stopped in at the local Checker Auto Parts and they had the OBD1 tester availible, three memory codes came up. #14 Profile ignition pickup circuit failure. #31 EGR valve position or exhaust pressure transducer sensor voltage low. #96 Fuel pump circuit failure or high speed fuel pump relay circuit failure. All the info for each kinda leads to replacing the fuel pump and EGR valve.
