Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 10-14-2006, 02:48 AM
guy_mu1 guy_mu1 is offline
2001 Tire Speed Rating
My current tires have Speed rating 'H'. Now if I put new tires of Speed Rating 'S', would there be any problem? Will there be any damage to car? Would i feel any difference in car performance?
Old 10-14-2006, 05:36 PM
JustSayGo JustSayGo is offline
Send a message via AIM to JustSayGo Send a message via Skype™ to JustSayGo
Re: 2001 Tire Speed Rating
If the tires are the same size, No problems. No damage. There are many other factors that affect tire performance. As a general rule I would expect most H rated tires to feel more performance than most S rated tires. You may feel some difference. Probably softer ride with some loss in cornering.
Old 10-14-2006, 06:42 PM
Hi JustSayGo,
Thank you for replying...You mentioned that S rated tires won't have as smoot ride as I am getting in H rated tires. You meant that I would have more jerks on a bumpy ride?
I have heard cornering work before for tires. What does that mean??
Old 10-14-2006, 11:05 PM
H rated tires are a higher speed rating and are likely to have tread design and other construction that make them more of a performance tire than an S rated tire. Sporty car vs more limo like. Yes H tires would tend to give more of a choppy ride.
Old 10-16-2006, 07:27 PM
Oh, I thought that as the speed rating is higher, it would have better tires and less jerks...I would like a smooth and quite ride, so I guess I will go with S rated tires now. Thanks a lot...
Can you please explain what is corning in terms of tire speed rating???
Old 10-16-2006, 09:25 PM
You may not be able to take sharp corners at as high a speed with the same stability.
Old 10-17-2006, 05:44 PM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Sorry to butt in but I believe the treads on H-rated tires are designed for driving straight and have less taction on the outer part of the tire to reduce friction. The S-rated are smoother ride but more traction to hold on to the road and hug curves a bit better. But as long as they are the same size you should be okay.
Again sorry to butt in, Bye.
