Old 10-13-2006, 11:17 PM
mitsu3kgt mitsu3kgt is offline
airbag module
Does it matter if I use any srs module off of a 3000gt or dodge stealth? I know that tey have model numbers, but I can't find a module with the same number as me.
Old 10-14-2006, 01:20 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: airbag module
3000gt, stealth, doesn't matter. only thing different in the cars are the bodies.
however, best to find one with the same model number, as you've obvserved.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 10-14-2006, 09:54 AM
Re: airbag module
What about vr4 or sl modules. Well a sl module work in a vr4?
Old 10-14-2006, 04:32 PM
Linebckr49's Avatar
Re: airbag module
same for all trim levels. just try to find one with a matching part number.
93 3000GT base
