Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 10-13-2006, 09:22 PM
trekkerjmm's Avatar
trekkerjmm trekkerjmm is offline
Service Traction Message
I went through some mud the other day now the "service traction" light comes on, any ideas?
Old 10-15-2006, 07:47 PM
Glen_T Glen_T is offline
Re: Service Traction Message
I'd suggest you check the ABS connector at each wheel. Because the traction control uses the ABS system, a bad connection at a wheel can cause the traction control light to turn on.
My light came on first thing in the morning when I first backed out of the garage, but would not return if I stopped and restarted the engine. Turned out to be a rear wheel ABS sensor thaht was bad (luckily replaced under warranty). But, you might get luck and it is just a bad connection...good luck, glen
Old 05-29-2007, 01:40 AM
fafmlg24 fafmlg24 is offline
when my abs light went on it turned out it was a rear tail light bulb. the abs system goes through the rear lights so check those out. make sure the connectors are not coroded in the tail lights. if they are you can order a replacement socket from gm directly or form gmpartsdirect.com
hope that helps
Old 05-29-2007, 07:47 AM
dcarver dcarver is offline
Also check the brake fluid level and vacuum connection to the (brake) master cylinder: I had a similar intermittent problem.
Old 05-29-2007, 09:07 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
This thread is a little out of date to be adding to. In the future, if you have more to add, it is a better idea to start a new thread with the useful information you have provided.
Thread closed.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Closed Thread
