Old 09-05-2002, 11:17 PM
danasher danasher is offline
Unhappy i need help
when i start my 87 prelude and warms up it idles very irraticly. how can i solve the prob or what part do i need.
Old 09-11-2002, 11:53 PM
88_SC_CRX_Si 88_SC_CRX_Si is offline
Is it revving up and down, uncontrollably...? Also, check your ECU to see if it's not flashing any codes...
If it's not flashing any codes, then try re-setting the idle, following the proper steps of un-plugging the EACV. The ECU will throw a code, just re-set it, along with re-plugging the EACV connector.
Next, check your coolant level and see if you can bleed any trapped air out of the system. Just pull the cap off while the engine is cold. Then let it warm-up and the cooling fans kick on two or three times. It may take a while so give it plenty of time. The trapped air, will raise hell with the ECT sensor...
Post again if this does not help...
"Noth'in like Induction..."
88' CRX Si - JRSC @ 6psi Z6 Mini-Me, JDM SiR Conversion
NOS #5122, JR Liquid InterCooling System
ZYDNE SECU, 450's
B&M FP Set, B&M Command Flo
AutoMeter - Phantom FP, A/F, N2O, Boost gauges & pods,
ARP HSKit, AEM Pads, 87' HF Drums, DYI CAI
Old 09-12-2002, 07:11 AM
rx racer's Avatar
rx racer rx racer is offline
sound like a vacuum leak. cheak all vacum hoses and make sure the are connecetd and tigltly secured
1993 rx7
1994 Civic Ex
