Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 10-13-2006, 03:14 PM
burkey61 burkey61 is offline
No Spark
I have a 94 ranger 2WD XLT with a 2.3L. I have no spark. I have replaced the crank sensor, still no spark, have replaced the ignition control module, still no spark, Have replaced the crank pully(with the vanes), and yes you guessed it no spark!! Running out of money fast. Have checked the coil packs, have 13.9 ohms on the secondary and 3.1 on the primary. Any ideas anyone?
Old 10-13-2006, 04:50 PM
rhandwor rhandwor is offline
Re: No Spark
Their is an eec relaywhich supplies power to the computer system. I think it is in the right kick panel. Their should be a computer ground to check close by. Fuseable links should be around the right shock. Check for voltage at the ignition switch. On the steering column about 12 to 18 inchs from the key switch. The relay if somebody is trying to start it should click. Put your finger on it and feel it. I got three bad modules in a row. Advance or auto zone check them for free. Relays are about $3.00 at the yard and $30.00 at a parts store and $45.00 at the dealer. I have used 10 wire with two male connectors and if you start up buy a new one. This is only for test. Ford used large prongs for main power and small prongs for the relay coil.
Old 10-13-2006, 07:16 PM
Re: No Spark
Thanks, that actually worked, It was a bad ground. Thanks for your help
