Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 10-13-2006, 12:09 AM
VTECSI00 VTECSI00 is offline
need help can't seem to adj valve springs
tried adj valves on 00 si.......has crower dual springs,stage 2 cams, titanium retainers, and i set it to TDC and i loosened the lock nut and turn the screw to loosen the spring and it doesn't loosen or tighten......i am in need of help please....i am wondering if the rockers and latch pads might have been put on the wrong sides?????????
Old 10-18-2006, 05:49 PM
lorunner lorunner is offline
Re: need help can't seem to adj valve springs
Did you loosen the jam nut? the screw goes through a nut. That nut needs to be loosened adn then the screw will turn. Once the proper clearance is set then tighten the nut so the screw won't back off.
Stop asking me about radio codes I cant get them anymore!!!
Old 10-23-2006, 10:46 AM
jclark jclark is offline
Make sure the TDC is on the compression stroke.
If not, you're 180 degrees off and the spring is under tension.
There should be play in the rocker if you're on the compression stroke.
Jim C.
