exhaust question
I am taking my down pipe off because this
![]() the damn thing feel apart and now it sound bad. I already got my down pipe off but where the O2 sensor is located at is still atached to the cat. well my question is could something go wrong if I cut it because its being a %$#@ to take off? any sudgestions would really be appreciated.
![]() Wheels/brakes/Suspension: Hawk HPS Brake Pads R1 concepts cross drilled and slotted rotors Megan Racing "Street Series" Coilover Kit Adjustable control arms adjustable toe arms exhaust: 2.5" test pipe 2.5" cat back (angled out) Misc.: Short throw shifter Soon to come: TT Conversion w/AEM UEGO, AEM Ttru-boost, APEXi AFC II, solid motormounts, Dattalogger (hand held halo), etc... |
Re: exhaust question
it kinda looks like it broke off. you need to keep your o2. spray a penetrating lubricant on it and wait a while.
If your putting on a new one then yeah cut that thing off.. what are you using to get it off?
Right now is soaking in WD-40
look at why it broke (poor welding IMO)
but has someone taken their sensor out and driven the car without a problem or could something go wrong?
1. take english class.
2. get new motor mounts. |
sorry for being a dick in my last post. spent the last 7 hours at the bars.
anyways, i would use this as an excuse to get an aftermarket downpipe. Stillen makes a very nice one if you have the spare cash. |
Soak it with PB blaster overnight (much better than wd40) and use a breaker bar, if that doesn't work, air tools.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
i'm confused by the 2nd pic you posted.
![]() the downpipe on top is the stocker. the one below is your's that broke? it looks like a stocker that someone cut off the front flex section then welded a straight pipe on??? what's the dealio?
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
thats what I said.
the prevoius owner did it, and apparently he sucks at welding because that thing just feel apart. I got the top one from J-Groove (3si)
I've been searching and alot of people extend the wires so now.
the wires are cut so its easier to take off. ![]() ![]() but now that I see that everything is full of rust and bonded together, I will only be running with a open test pipe until a GB takes place on 3si
just buy a ebay down pipe cheap and it works GREAT!
