Old 08-28-2001, 01:25 AM
watershower watershower is offline
Unhappy My car hesitates to start in the morning!
What could be the reason?
- Bad Battery
- Bad Fuel Filter
- Bad Fuel Pump
If it was for the last two, then why only in the morning.
Help is appreciated!
It' s a Jeep Grand Cherokee 4.0L with Automatic Tranny.
Old 08-28-2001, 01:50 AM
TheMan5952 TheMan5952 is offline
Volvo Guy
Send a message via AIM to TheMan5952
Check your air filter, if those get clogged you get ahrd start problems. And also it could be your cold start injector.
-Joe- '02 Volvo S60 T5
Sold!1993 volvo 850
Intake, Exhaust, Springs, Shock, I.C.E.
Old 08-28-2001, 09:39 AM
Question
Originally posted by TheMan5952
....And also it could be your cold start injector.
Thanks Man for the reply; What is a cold start injector?
Old 08-28-2001, 08:33 PM
olds88's Avatar
olds88 olds88 is offline
Re: My car hesitates to start in the morning!
It' s a Jeep Grand Cherokee 4.0L with Automatic Tranny. [/b][/quote]
IT IS THE FUEL PUMP IF IT IS A 1999 OR NEWER CHRYSLER CURENTLY HAS A TSB ON THEM VERY COMMON PROBLEM. BUT IF YOUR OUT OF WARRENTY YOU WILL HAVE TO PAY. IF IT IS OLDER THAN 1998 THEN I DONT KNOW
what is the world coming to???
Old 08-28-2001, 08:35 PM
olds88's Avatar
BTW 4.0 LITER CHRYSLER STRAIGHT SIXES DONT HAVE A COLD START INJECTION OR FOR THAT FACT I HAVE NEVER SEEN A CHRYSLER JEEP WITH ONE.
THE RESON FOR THE COLD START IN THE MORNIGS IS DUE TO THE CHECK BALL IN THE FUEL PUMP NOT HOLDING GAS IN THE LINE AND OVER NIGHT IT ALL LEAKES BACK INTO THE TANK SO WHEN YOU GO TO START THE CAR IT IS JUST GETTING AIR FOR A FEW MINS UNTIL THE PUMP PUSHES GAS TO THE INJECTORS
I HOPE I HAVE HELPED YOU OUT
Old 08-29-2001, 01:44 AM
Volvo Guy
I didn't know if ti had one so I suggested it in case it might, I didn't know they didn't have them, it just a common problem in older volvos.
Sold!1993 volvo 850
Old 08-30-2001, 09:11 PM
olds88's Avatar
I WASNT TRYING TO MEAN ANY DISRESPECT
Old 09-01-2001, 02:14 AM
Volvo Guy
I didn't say you did, I was just explaining my self. BTW, your caps lock is on.
Sold!1993 volvo 850
Old 09-02-2001, 02:24 AM
Thanks Man and Old88
Well, I tell what I did:
I got a pressure gauge and hooked it to the fuel manifold this morning. The pressure reading was ZERO psi.
I switched the car ON/ OFF then ON/ OFF (without cranking the car) and the psi went 10 psi up at each time untill reaching 33 psi then stopped their. A cranked the car and Wooo, start from the first time.
I believe it is the Check Valve (if any is going Bad)
I cannot think of anything else.
BTW: Why the pump do not keep running after turning power ON. In this way it will keep the line pressurized w/o the need to turning the switch ON/ OFF repeatedly.
Thanks Guys.
Old 09-02-2001, 08:19 PM
olds88's Avatar
because if you were just sitting there with out the engine running listeng to your radio it would kill the battery and maybe burn the fuel pump up btw those fue lpumps are quite pricy
