Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-12-2006, 10:31 PM
GUnitD420's Avatar
GUnitD420 GUnitD420 is offline
Send a message via AIM to GUnitD420
Tune-Up
It just snowed here in MI. So I'm looking at doing a quick tune-up for the winter. This is my first winter with a turbo dsm is there anything I should concentrate on. I'm thinking I'll need a new battery soon. ( now that it's cold it starts a little rough) But what are some other thing I can look for.
Thanks
91' Mitsu Eclipse GS 5-Speed DOA Selling.
95' Eagle Talon TSI AWD 5-Speed (Overheatin' No More) daily Driver
Old 10-12-2006, 10:42 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Tune-Up
Fuel filter, new spark plugs (don't forget to gap them ) would be good ideas, along with a coolant flush
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 10-12-2006, 11:22 PM
Killa's Avatar
Killa Killa is offline
Re: Tune-Up
http://www.dsmtuners.com/forums/show...#post151006887
very week or every 250 miles or when you get gas/fuel:
1) Check engine oil level
2) Check brake fuild level
3) Check tires and tire pressures
Every 3000 miles or 3 months
1) Change engine oil and oil filter
- The most commonly used oil is synthetic 10W30, 10W40 and 15W50.
Every 6000 miles or 6 months
1) Rotate tires
Every 15000 miles or 12 months
1) Change PCV valve. (When you buy it, blow on one end and then blow on another, you should only be able to blow one side. If you can blow on both sides, it is bad, get another one)
2) Change spark plugs
- If you have no or mild mods get - NGK BPR6ES or Autolite 63 Copper
- If you have moderate mods get - NGK BPR7ES or Autolite 62 Copper
- If you have a LOT of mods get - NGKJ BPR8ES
Gap plugs to 0.028 to 0.031". Use no other plugs. No platinum or dual electrode stuff.
Every 30000 miles or 24 months
1) Replace air filter
2) Spark plug wires - (I use NGK premium wires: part# ME77, stock# 8100)
3) Coolant flush - 50/50 (with 2 bottles of water wetter if you want to use it)
4) Change the tranny fluid - most commonly used on manual transmissions is Pennzoil Synchromesh, which is a cheaper alternative to BG Synchroshift.
5) Change the transfer case and rear diff fluid (if you have AWD) - most commonly used gear oil is Redline Heavy Shockproof gear oil.
Every 60000 or 48 months
1) Replace fuel filter
2) Timing belt change: A complete list of 60k timing belt service would include all these:
- Timing belt
- Balance shaft belt
- Timing Tensioner
- Water pump
- Timing belt tensioner pulley
- Balance shaft tensioner pulley
- Idler pulley
- Crank seal
- Oil pump seal
- Balance shaft seal
- 2 Cam seals
- Harmonic balancer
- All other belts
Get only MITSUBISHI parts for the list above. OEM part does not always mean that the part is made by MITSUBISHI. If you don't know where to but parts from, this is a good start - http://www.dsmtuners.com/forums/showthread.php?t=238788.
COpy and past
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
