Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 10-12-2006, 09:03 PM
SocGT SocGT is offline
Question Sunfire Bearing??
K so im getting some weird noise from my passenger side wheel well thats prety much only noticeable from inside the car. I jacked it up and ive come to teh conclusion its coming from therebut since nothign i see is bent im wondering if it iis maybe a bearing? or a tie rod?? i noticed the wheel wobbles a very small bit like maybe 2 mm when its in gear and the tires are going. I only get this sound when its over 40 km an hour, im just wondering if anyone would know wut im maybe looking at to fix?? and if anybody has seen anythign similar. It sounds like a metal scrapping almost and im scared to drive it though it drives perfect. When totally cranked to turn there is no sound from the wheel wells its only when im driving straight can anyone help!!! thanks alot if u can!!!!!!!
thanks alot!!!
Old 10-14-2006, 12:01 AM
muff34 muff34 is offline
Re: Sunfire Bearing??
do a forum search here or go to autozone.com . look under repair info . put in your vehicle info . it will show you how to do a front hub / bearing removal /install.sounds like bearing issue to me but i could be wrong. When mine went out what I found was that when going down the highway I could hear a "NOISE" from front end. If I turned /wiggled the steering wheel abit the "NOISE" would disappear for a brief moment . tie rod would not make a metal scrapping noise. grab the tie rod and try to move it back and forth or up and down. any chance it could be a brake issue? Good luck
Muff
Life Is A Highway ,Enjoy The Ride
