Old 09-05-2002, 08:26 PM
iVteC_bOi iVteC_bOi is offline
Send a message via AIM to iVteC_bOi
engine b18c5 typeR
hey will i want to do a engine swap for my 88 civic and iam not sure wat to get...but i want to get a b18c5 engine...and i know that is really hard to get...so i am trying to fine a place that cheap and that type of engine...do think that engine is to strong for the car?? wat kind of engine should i get???(help) i want a vtec on tho...willl i hope u guys could help me ok...peace
Old 09-05-2002, 08:36 PM
EF_LSVtec's Avatar
EF_LSVtec EF_LSVtec is offline
Send a message via AIM to EF_LSVtec
You can never have an engine that's too strong...B18C5 is one of the best engine if you can find one. Take a pick, B16A1/2, B16B, B18C, B18C5...Any of the B series Vtec motors is worth your effort. I'd stay away from the H22 motor though, unless you plan on just drag racing...:flash:
AF Bay Area Crew
Fully Built LSVtec Motor (245.8 whp/164.6 torque)
88 DX Hatch to JDM SiR conversion
Retired SOLD 1/08
Licensed Mortgage Consultant (Calif.)
Cellular 415.699.1797
Old 09-05-2002, 08:42 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
B18 is not too strong for the car. From what I hear, B18's are the best engines to turbo.
But you still have alot of other choices for engines, but it depends on what your needs are...
Is this going to be your daily driver, or a track-only car?
What trim-level is your civic now (DX, Si, Std., etc.)?
What kind of driving do you plan on doing (drag, autocross, etc.)?
What kind of 1/4 mile time are you looking to achieve?
How much money are you willing to spend on a swap?
Will you be doing the swap yourself, or will you be paying a shop to do it?
Old 09-05-2002, 08:50 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
a type r motor is the worst motor you could ever buy, unless you plan on leaving the internals stock, the head and block stock
Old 09-05-2002, 09:17 PM
yea
will i have a dx engine right now...and am planning to do a daily driving and race sometimes in the street...if someone wants to race u know...i want to try to get at least a high 13 or a low 12...it that possible...hhaha..willl am willing to spend at leas 5gz on it or soo...and let a shop do it..will and i want to get a low miles one and a clean one too so i coould put it in the show and try to win something...and then when i save up try to coustimize my interior..tooo...will wat should i do or get??
Old 09-06-2002, 01:32 AM
EF_LSVtec's Avatar
Why is that? Just curious...
AF Bay Area Crew
Retired SOLD 1/08
Old 09-06-2002, 04:13 AM
if you plan on leaving the stock pistons and cams then yeah get the type r, but if you plan to build a race motor then its a waste. why you asked
first in your race motor, hmm lets up the comp ratio cause the type r motor isnt high enough, ok there goes your $5000 type r pistons for $400 higher comp pistons, so why buy type r when your gonna up the comp ratio anyways.
then the cams, well if racing your gonna need more radical cams then stock type r cams, well there goes your $5000 cams for $400 cams. also there goes your whole type r valvetrain for an aftermarket to match the radical cams and high hp motor. so why buy the type r when your gonna upgrade the valves and cams anyways.
whats left, hmm the high flow type r head and intake mani. well the type r port isnt good enough for a race motor, and a aftermarket intake is in need, so there goes your $5000 port and intake manifold for a port and $500 intake mani.
so why buy a type r motor when your gonna replace everything anyways. but you can spend your $5000 and all that money to fix it up, but i am gonna buy my $3000 gsr motor, which after you add all those aftermarket parts will be no different than your fixed up type r motor with the same parts. plus i used that extra $2000 to buy all those parts that i need, but youll have to spend $5000 plus all the money needed to buy those parts
so after all those parts the gsr and type r motor will be the same, so why spend $7000 when you onllly need to spend $5000
Old 09-06-2002, 08:54 AM
turbcivic's Avatar
turbcivic turbcivic is offline
You took the words right out my mouth. I would go with B18C1 motor. The C5 is good stock and only stock.
Old 09-06-2002, 10:25 AM
EF_LSVtec's Avatar
IC...So if you can get a type R motor for $3000, do you think you're better off getting a GSR for the same price? Do you guys know, if the Type R block and head was made any different that the other B series Vtec motors? Strength wise? or are the oil squirters any different? block has thicker aluminum etc? :flash:
AF Bay Area Crew
Retired SOLD 1/08
Old 09-06-2002, 10:30 AM
djAkira36's Avatar
djAkira36 djAkira36 is offline
Send a message via AIM to djAkira36 Send a message via Yahoo to djAkira36
or if you are patient and have the know how, an slightly cheaper way to go is doing a, ls/vtec hybrid conversion......
Highs: you get the low end torque of an non vtec with the high end of a vtec, higher hp potential whether you go turbo or n/a, there a few hybrids out there making close to 250hp n/a... for boosted cars, you have a much stronger block to work with and can run 300+hp reliably...
Lows: Must have patience, finding all the needed parts can be frustrating, hybrids are still a bit sketchy, buildup can be confusing even though it is actually quite simple to do the initial coversion, and theres alot of trial and error involved..... but hybrids are starting to become more common.
I myself started off with a B20 block and eventually accquired a usdm ITR head, Im still in the building process because I decided(MAYBE) to scrap the B20 block for something a lil bit lighter like a B18A, the B20 made my car feel like it was running an H22...... So if anyone is interested in a moderatly built B20 block ready to be mated to a B series vtec head, drop me a PM.... Ill list the specs upon request..
SURGEON GENERAL'S WARNING:
APC products may cause CANCER!!!!!
Old 09-06-2002, 12:33 PM
91civicDXdude's Avatar
i've heard thats lots of lsvtec motors throw a rod easily. that is something to consider. rod/stroke ratio is a little off "optimum" so in reality you're not utilizing the high revving vtec because you have a low revving high torque block
Old 09-06-2002, 01:54 PM
Redline_civic91 Redline_civic91 is offline
Send a message via Yahoo to Redline_civic91
djakira how was your b-20 running. im waiting for mine to come out the shop and just curious what kinda power im gonna be felling w/it. its the stock b-20b head non vtec. I have the v-tec computer in there but yet to add the head. will do that in a few months. but let me know how the power feels.
91 civic b20/vtec=sold
95 acura integra=sold
02 chevy silverado=totalled
95 honda accord=please i hope nothing happens to this!
Old 09-06-2002, 02:48 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
I definatley agree with civickiller! Well u said u have 5g's to spend rite? Lets say u get a b16 complete kit for about 1800 (depending where u buy it from) and planning to install it yourself. Then you'll have around 3200 bucks left to spend on it. I'd say you'll be in the low 13's with that money left over.
Old 09-06-2002, 02:55 PM
EF_LSVtec's Avatar
Civickiller, mellowboy:angel: $3200 will buy you a lot of speed...
AF Bay Area Crew
Retired SOLD 1/08
Old 09-07-2002, 10:20 AM
turbcivic's Avatar
Ls/Vtec kick ass if they are built right. My friend has got one in his crx and it hauls ass. 14.1 all motor. Just got to build the bottom end a little before revving it up to high.
