Old 10-12-2006, 03:55 PM
Rob Rangel Rob Rangel is offline
Send a message via MSN to Rob Rangel
need help
alright so, my 93 350 started to idle a little rough, i thought it might be dirty injectors so i used an injecter and valve cleaner fuel additive. my exhaust started to blow smoke on start ups and we wrote it off as a side effect of the valve cleaner. im still finishing up the tank and now the idle has actually gotten worse, today it barely started and had the roughest idle ive ever heard on a vehicle. it sounded like a weed-eater that wanted to die, and then it did die twice, finally i got it started and was able to get home. any one ever see this problem before?
Old 10-12-2006, 09:28 PM
2000CAYukon 2000CAYukon is offline
Re: need help
Are both injectors firing? (take off the air cleaner to see)
Would be good to check fuel pressure (need a special fuel pressure tester for TBI unfortunately).
When was the last time it was tuned up or fuel filter replaced?
How do the plugs and wires look? Cap and Rotor?
Check for vacuum leaks. Inspect EGR for proper operation. Has the 02 ever been replaced?
Is the check engine light on? If so, need to find out what codes are stored.
//2000CAYukon
Old 10-13-2006, 01:52 AM
Re: need help
well now the truck has almost no throttle response at low rpm, anywhere over 2000 rpm its fine. the check engine light is on, how do i check what codes are stored? also i dont know if this would help in diagnosing, but the exhaust has a very odd smell to it. tomorrow, ill go ahead and check the injectors, and probably also the fuel filter. thanks for any help
Old 10-13-2006, 03:07 AM
BowtiePowerhouse BowtiePowerhouse is offline
Re: need help
smell like rotten eggs? define the exhaust smell if u can
Old 10-13-2006, 01:00 PM
texasboy05's Avatar
texasboy05 texasboy05 is offline
Re: need help
go to autozone and rent a scanner for about 250, ull get ur money back when u return it. and itll pull a code and theyll tell u whats up. dont rely on doin this too much cuz their scanners are crap
Old 10-13-2006, 01:26 PM
Re: need help
www.troublecodes.net/GM and a paper clip will get you the code(s).
See what the codes are first. You could be running rich.
//2000CAYukon
Old 10-16-2006, 10:05 AM
69Charger 69Charger is offline
Send a message via MSN to 69Charger
Re: need help
Sounds like the symptoms of a wet distributor cap...
Mark Mcknight
Elmvale Truck & 4x4
(705)-715-7867
Elmvale, Ontario
87 Mustang GT, 5.0L 5 spd, MSD ignition, BBK tubes, flowmasters, tri-ax shifter, 4.10 gears
69 Charger SE, stroked & poked 383,727 over 550rwhp
86 Chevy 2500 4x4 Plow truck, 350/TH400, 8ft fisher plow
