Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-12-2006, 01:45 PM
ABigWeaney ABigWeaney is offline
intake manifold leak
ok i finally did some boost leak tests and found some on the bov and fixed them.. but from the intake manifold there is a lot of air comming out of it and i cant seem to find it.. or would it be better to get all of the gaskets to take the manifold off and replace them? and what is required to do that?
Old 10-12-2006, 02:06 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: intake manifold leak
You said it. Your best bet is to remove the manifold and replace the gasket. You can take the manifold off with basic handtools, some of the positions are akward but with extensions it shouldn't take long.
But to make sure that it's the gasket that is leaking and not the actual manifold itself. You can take some soapy water, or some CARB cleaner / engine degreaser and spray it on the the manifold where it meets the head and see if you get any bubbles. It'll show you were the leaks on the manifold are coming from. Other area's to check would also be the TB and TB elbow.
1991 GSX 2.3 Stroker
Old 10-12-2006, 09:13 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
I usually mix up some dish soap and water in a spray bottle when i do leak test
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 10-13-2006, 07:45 AM
ok ill try it thanks
Old 10-13-2006, 08:18 AM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
wow a noob post that makes good sence! congrats lol hope you find the leak...
