Go Back   Automotive Forums Car Chat > Pontiac > General Discussion
Old 10-11-2006, 10:04 PM
natmyers natmyers is offline
Please help! 1989 Bonneville
Hi. Lots of good info here. My son is trying to get the hub off the rear drum brake. He can't get it off and he's tried for hours.
Is there that tensioner screw on this year models? We see a small hole but don't know if that's where to loosen the brakes or what.
We have very, very limited knowledge. His brake line (I guess it's called) is leaking and we want to fix it.
Thanks for the help.
Natalie
Old 10-12-2006, 06:36 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Please help! 1989 Bonneville
There is a tensioner screw on these brakes. There should be access on the backing plate, they are usually on the bottom and there is a rubber plug in the hole. I suggest that he spray the area around the center of the drum and the lug holes with a good penetrating lube like PB blaster. This will help to free the rust. You may actually need to get a drum puller to remove the drum from the hub. They can be rented at an autoparts store.
Old 10-12-2006, 09:42 AM
ChemMan ChemMan is offline
I've actually had a brake drum rust on to my old ford so badly that I bent the drum getting it off. Do like GTP Dad said and spray penetrating fluid around the hub and lug holes, and then get a small mallet and give the drum a few good whacks around the outer edge of the face of the drum to help break it loose. It is also possible that you need to back the brake pads off a bit like you asked. Don't be too upset if you bend the drum when you take it off with a puller, just replace it.
2010 Mazda CX-7 2.5L 12000 miles
2003 Chevy S10 Extreme 4.3L 57000 miles
1995 Buick Lesabre Custom 86000 miles RIP
2002 Pontiac Sunfire SE 130000 miles RIP
1997 Pontiac Bonneville SE 91106 miles Totaled by attempt to steal the car!!
R.I.P. 1978 Ford Fairmont 83000 miles
