Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 10-11-2006, 09:17 PM
maxx7 maxx7 is offline
2006 Denali ticking noise @ 23 mph????
2006 Denali 4X4 v8 has loud ticking noise when reach speed of 23 mph-- GM states this normal operation due to 8 cyl dropping to 4cyl-----
has anyone experience this? this is not a typical noise that a $40k vehicle should be making
Old 10-12-2006, 03:45 PM
maxwedge maxwedge is offline
A990 racer
Re: 2006 Denali ticking noise @ 23 mph????
Welcome to AF. This is really not the right forum for this. Probably the Yukon forum is more appropriate, But I don't think, unless you find an owner of a similar truck, that any of us can tell you if a percieved noise in your truck is normal regardless of purchase cost. You should be addressing that with GMC customer service dept. and/or the dealer..
Old 10-12-2006, 05:24 PM
rodeo02 rodeo02 is offline
A dealer should atleast allow you to test drive another similarly equipped truck to see if it sounds the same as yours.
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 10-18-2006, 10:08 AM
why do you think I should be in the Yukon forum? that's a completely different vehicle---- the noise is not perceived -- the service dept is aware of the noise and have replaced several parts (driveshaft, entire exhaust system, tension pully) only to tell me it's normal------
Old 10-18-2006, 02:59 PM
A990 racer
Sorry, did not know the Envoy had it's own Denali model. So are you asking for any advice/resolution to this noise on the forum or whether there is another owner here with the same issue? Obviously sitting at our desks we are somewhat handicapped relative to hearing any noise, percieved or not.
Old 10-18-2006, 08:43 PM
i'm trying to see if any other owner has experienced the same problem - i need to know if this is an isolated problem or if indeed a "normal" noise
Old 10-19-2006, 05:18 PM
Again, you purchased a $40K vehicle. The dealership that sold it to you wont let you test drive another to atleast see if their theory on the noise is accurate? If they cant fix it, they atleast owe you some truth to their diagnosis.
Joel
Old 10-20-2006, 08:25 AM
Yes, I have driven another vehicle at the dealership and no noise was heard. GM states the vehicle needs to be past the break-in period (1,000 - 3,000 miles) that's why I was unable to hear noise in another vehicle. Dealership states they have not rec'd any similar problems from other owners. I'm very unhappy and trying to find someone that has experienced the same problem.
Old 08-25-2008, 09:12 PM
bankroll bankroll is offline
Did you ever hear anything back about this..I have the same vehicle and am hearing the same sounds...
Old 08-26-2008, 09:17 AM
A990 racer
This is 2 years old, I doubt you will find anything here. I will give this 2 days then the thread is closed.
Old 09-09-2008, 03:14 PM
russelld russelld is offline
I have the 2005 envoy denali and yes i have the same problem but only coasting wile the trany is still in top gear if you drop it to gear 3 does the noise stop.
Old 09-11-2008, 02:31 PM
rtobrian rtobrian is offline
I have an 06 Envoy Denali with 33k miles and I haven't experienced any ticking noise. If you're not happy with what one dealership says or does then go to another GM dealer. I'm a GM/UAW employee and I can't stand to see dealerships give people the run around.
