Go Back   Automotive Forums Car Chat > Oldsmobile > Achieva
Old 10-11-2006, 05:23 PM
kenyakaos kenyakaos is offline
1997 Olds Achieva power window quit
So all of my power windows went out at the same time, I checked the Fuse/Breaker and that wasn't it. Someone at Checker Auto Parts told me to check the switch board in the driver side door, but I don't know how, If anyone knows anything I could do, it would be greatly appreciated........ I just don't want to spend a fortune to have it looked at somewhere.....Thanks
Old 10-12-2006, 08:32 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 1997 Olds Achieva power window quit
Welcome to AF.
The suggestion sounds good. From the power window circuit breaker the 12 volts needed feeds over to the driver's side switch assembly. To check it will require removal of the door panel or the switch panel if removeable by itself. You can use a 12 volt test lamp or multimeter to check the voltage.
Timeslip 08/12/06
AF Community Guidelines
