Old 10-11-2006, 08:00 AM
Whoaru99 Whoaru99 is offline
Bleeding brakes - 1994 LeSabre - proper sequence?
Doing some brake work and I have run into controversy on the bleeding procedure. Since I don't have a shop manual, I went to the library and consulted a Chilton's book. The problem is that the Chilton's only went to 1991 or 1992, and again, mine is a 1994.
The controversy is that for the earlier models, the Chilton book said the bleeding sequence was criss-cross (RF, LR, LF, RR, if I remember properly) BUT, my "old school" mentality is longest to shortest as in RR, LR, RF, LF.
So, anyone with a factory service manual that covers 1994 that could clear this up for me, I'd sure appreciate it. Either method probably "works", but I like to use the most correct methods.
I also did some searching here and the results seem to parallel my thoughts on the longest to shortest method, but then why the criss-cross recommendation for at least some years?
TIA.
Old 10-11-2006, 10:22 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Bleeding brakes - 1994 LeSabre - proper sequence?
This link may help;
1986-1999 Brake Bleed Procedure
Old 10-11-2006, 10:54 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Originally Posted by HotZ28
You know it makes you wonder Bo what the proper bleeding sequence is. Everyone you ask will give you their method but who is to say it is right or wrong. Even service manuals differ.
I recall GM recommends RR, LF, LR, RF.
Timeslip 08/12/06
AF Community Guidelines
Old 10-11-2006, 12:02 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Wierd... I've always heard longest to shortest (RR, LR, RF, LF) and I've never had any trouble doing it that way.
Is there a reason for the wierd criss-crossing?
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 10-11-2006, 06:42 PM
BNaylor's Avatar
Oh you mean the diagonal pattern? I don't have a clue.
It is just the pattern GM specifies in the service manual covering ABS braking systems. I use one of the others and it works for me.
Timeslip 08/12/06
Old 10-11-2006, 07:06 PM
Alibi's Avatar
GM must have some reason for it but I can't think of why. Maybe they just try to confuse the do-it-yourselfer enough to make them bring it into a dealer$hip.
Wierd. Learn something new everyday though.
-Eric
Old 10-11-2006, 09:07 PM
HotZ28's Avatar
AF Moderator Elite
Just to help eliminate some confusion, the bleed procedure is determined by the year of the car, type of ABS system and whether or not, it has traction control.
Teves Ii Anti-lock Brake System
Teves Mark Iv Anti-lock Brake System
Delco Vi And Delco Bosch V Anti-lock Braking Systems
Old 10-11-2006, 09:46 PM
BNaylor's Avatar
Interesting annectodal information, however, I'm still confused.
The poster has a 94 LeSabre, therefore, he shoud have an ABS VI system. Since that is the case then the proper bleeding sequence as specified by GM is:
RR, LF, LR, RF
I believe that was the info requested by the OP. Are we all in agreement?
Timeslip 08/12/06
Old 10-11-2006, 10:06 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
FWD's use a diagonal-split master cylinder. One section controls a front brake and a rear brake. That way if one section quits, you'll still have one front brake working.
This would be correct.
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 10-12-2006, 06:55 PM
Thanks all.
RR, LF, LR, RF it shall be.....
