Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-11-2006, 12:07 AM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
what injectors for t28
Ive been lookin around for new mods for my 98 eclipse gsx. I decided i want to go with the fp big t28, I want more horsepower but am not concerned with going unGodly fast. What size injectors should i run i plan on runnin at 14-15 psi daily. also what size fuel pump 255?. As far as intercoolers would a aftermarket one be better or would the stock ic be more practical? Would a SAFC be necessary if i plan on upgrading the turbo and fuel system or is that better left for the bigger turbos? Id like to make as much power as i can out of the t28 but thats as big as i plan on going at the moment. I know its alot of stupid questions but id appreciate any suggestions thanks.
Old 10-11-2006, 12:16 AM
steviek's Avatar
steviek steviek is offline
Re: what injectors for t28
OK lets start at the beginning here. You can't just toss on that turbo and just max it out. If you want to max out this turbo you first have to get the 255 with a fpr. Then your gonna need dsm link cause you will need at least 720cc which is more then safc can compensate for. A front mount intercooler is a must for that kind of horsepower. you will need a mbc I'm kinda assuming you already have one and a BOV though. Forget daily driver PSI tell me how much you want Max hp and max PSI.
And post your mods up.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 10-11-2006, 12:35 AM
Well I got the boost gauge, turbo xs boost controller, the k&n cold air intake, and megan 3 inch downpipe and catback exhaust. Ive got the 1st gen BOV, with the new stock ngk plugs and wires on order at the moment. My goal is 300 hp out of the T28 or anywhere close to that with max psi around 15-16. I knew i had to upgrade the fuel system with the fuel pump and the injectors but wasnt aware that id need the pressure regulator with 720cc injectors and dsm link. I can do any of the mechanical stuff myself but Im not too smart when it comes to the computer modifications with the dsm link . But if thats what i need i guess ill have to learn
Old 10-11-2006, 12:47 AM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
For 300hp...you probably only need some 550's maybe some 650's I think 720's would be overkill...and you would definatly want an AFC or something to control the bigger injectors....and you will want some sort of datalogging software to help you tune....with the fuel pump you can probably get away with the 190lph....with the intercooler you dont necessarily need to put a front mount on...you can upgrade your side mount and be fine....and it will be cheaper...but there are good fmic kits on ebay for pretty cheap...
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 10-11-2006, 01:37 AM
steviek's Avatar
yea but lets not get too far ahead. If you only want 300 hp the t28 is not the right choice. 16g all the way for that powerband cheaper! and hes right 300 hp setup go with safc2 550's and 190 basically my set up.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 10-11-2006, 02:57 PM
Well i thought about the t28 because its a direct replacement for the t25. But if im gonna need to do the the SAFC then the evo 3 does seem like the better way to go. I was lookin up parts for that; 500 for the turbo and 300 for the install kit on machv.com. thats about the same price close to 800 for a fp big t28. with the evo3 16G are you required to put on that new exhaust manifold and O2 sensor housing, or can you use the stock parts?
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 10-11-2006, 03:52 PM
Killa_DSM's Avatar
Killa_DSM Killa_DSM is offline
I wouldnt look for parts at Machv.com. They are WAY overpriced, and plus its easy to put your own kit together. A couple gaskets, fuel lines, and a J-Pipe. Thats all you really need. And not, you can use your stock exhaust mani and o2 housing.
If I was in your position I would go with teh Evo3.
"Life begins at 20psi"
97 Eclipse GST-X 5spd
PTE 5031e/pte 880cc/vr4 fuel pump/Devils Own Water injection 12gph nozzle/pre turbo meth injection/fmic 28x10.5x3.5/greddy type-s bov/12" K&N/FP intake/dsmlink/gm 3.3 bar/maft/blitz ebc/act 2600/act 6 puck/SS Clutch line/3" turboback.
Old 10-11-2006, 04:05 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Don't even bother with that POS t-28. Its bairly larger then a small 16g! Look at this chart and compare the diffrences in compressor and turbin sizes.
http://www.vfaq.com/mods/Turbo-compare.html
BEST PRICE ON INTERNET
Turbochargers.com 2g kit.. $699
http://www.turbochargers.com/store/p...roducts_id=186
Copper Antiseze stick $12
RRE.com "garage sale" 7cm turbo gaskets (turbo/o2) $10 + shipping
Mitsu Parts 4 new turbo bolts, 3 o2 bolts, 1 o2 nut $30ish
You really can't beat that price.. I've putt on two, 2g/14b's & one 2g/16g. The only thing I would hightly recomend is buying a 91 oil drain tube for the extra $30. Dont even bother fileing the 2g, it's a pain in the ass, and just not worth the $30 in my book. The 2g install kit from turbochargers.com comes with the 2 oil drain tube gaskets. MAKE SURE to buy the oil drain gaskets if you put your own kit together. DON'T TIGHTEN THE OIL DRAIN BOLTS MORE THEN 8-10FT/LB (snug tight) or you will spin the bolts and need to retap the holes on the oil pan. Trust me, you don't want to retap them... It's not fun...
Good day sir..
DSM geek
Old 10-11-2006, 04:30 PM
You will want 650cc/rw255hp/afpr to supply consistant fuel for the 16g. If you never planed on running more then 20psi on the evo316 you could get away with a 550cc/rw190 setup, though I would still hightly recomend buying an AFPR. Not everyone incounters over-run with the 190's but I was over running my stock fuel pressure regulator with a rewired stock 2g fuel pump and have the dsmlink logs to prove it.. Mod once, mod right!
DSM geek
Old 10-13-2006, 12:57 AM
Damn thats a lot better price than what i was lookin at before, and they throw in a new exhaust manifold. Thanks for the advice. I think thats what im gonna go for then forget that t28. Doesn't the 91 oil drain tube come in the kit or do i need to order that separate? And another stupid question, the kit says only works with the factory piping. I have aftermarket exhaust and intake but factory IC piping but i plan on upgrading that later will i still be able to do that? Thanks
94 Talon 1.8L-SOLD
