Old 10-10-2006, 08:01 PM
jewelllls jewelllls is offline
2001 blazer will not start on it's own but will run if fuel poured down throttle body
I have a 2001 blazer 160,000k and have just had the fuel pump replaced(not cheap). The truck would not start prior to this. May not have been the fuel pump?Hmmm. Anyway, if you pour say a quarter cup of fuel down the throttle body, it will start, and run and run and keep on running, yet it will not start on it's own. Any ideas out there, if I left anything out I apologize..
Old 10-10-2006, 09:17 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Re: 2001 blazer will not start on it's own but will run if fuel poured down throttle body
Welcome to AF, jewells.
How old is your battery, and has it been checked for a full charge recently? Sounds like the battery is weak. The battery voltage must be around(or a little higher)about 12.4, or 12.6 volts or a little higher.
If the battery is too low, the fuel pump will not prime the fuel system to the right pressure, and, in turn, fuel will not spary out the injectors to the cylinders as required, and a no start occurs.
You stated you changed the fuel pump recently, this may temporarly solve your problem because the pump is new and will have little resistance when the key is turned on. With a weak battery it will work for awhile until the new fuel pump gets broken in alittle, and then same problem again.
Either way, check your battery, and make sure your charging system is working properly too, as a weak charge will slowly, yet gradually discharge the system again.
Old 10-11-2006, 11:16 AM
alblogg's Avatar
alblogg alblogg is offline
After you check your battery you might need to check you connections at your pump. Are you getting power there, did you replace the wiring harness when you replaced the pump?
'99 Blazer LT Loaded, K&N Filter, Pioneer Super
Tuner,Viper
'98 Pontiac Grand Prix GT, 3.8
'88 K1500 Cheyenne, 5.0, stock, bought new
'86 Nissan 720 Trash Truck
'69 C/10 step side, 307, all original, second owner, in process of restore.
The person who says it cannot be done should not interrurt the person doing it.
Share your knowledge. It is a way to achieve immortality.
Allen- Paintman
Wrenchtwister
Broompusher
Old 10-11-2006, 03:41 PM
blazes9395's Avatar
Newbie mod
I agree, defiently a possibility, common too.
Old 10-12-2006, 04:55 AM
muddog321 muddog321 is offline
AF -Advisor
So, that was before the replcement or after? Lost me.
Starting pressure (test at the port on the fuel rail and tester from Actron is $35) is 60psi min (key on engine off) and then running 53psi or higher.
Old 10-13-2006, 07:13 AM
sreve sreve is offline
try cycling the key on to off about 3 times before you try to start it. if this works fuel pressure is bleeding off to zero. confirm with fuel pressure guage.
Old 10-14-2006, 08:53 PM
rhandwor rhandwor is offline
Pull the vacuum line to the fuel pressure regulator and check for gas if leaking replace. Otherwise check it with a pressure gage. If you pinch off the return line at a rubber hose will it start if so replace regulator.
Old 09-14-2011, 08:33 PM
dlo250 dlo250 is offline
I had the same problem. Car would crank and crank and not start. Had 60 PSI of pressure on the fuel rail, so I ruled that out. OOPS. After replacing a few electrical items, I found out GM has a known problem with the CSPI fuel injection system. There is a TSB that tells how to clean the injectors, but I went for the permanent fix, and installed the MFI injector spider. The conversion to MFI was no big deal, the parts look the same, but the way the part works is different. The information is here: http://members.shaw.ca/betterthanyou...g%20Poppet.htm
The first part shows the dealer procedure, the second part tells how to change to the MFI system. I had to take off the black intake manifold and the throttle body, but the gaskets are reusable. The "spider" sits inside the black intake manifold. The part looks like this: http://www.autozone.com/autozone/par...3_151679_5560_ Took me about 2 hours to do. Make sure you get some intake/carb cleaner and spray the heck out of everything while you are in. Started the car back up and it ran like a shaved ape. Before I actually thought the transmission was slipping it was so bad. Moral of the story, even if you have 60 psi on the rail, you still probably don't have fuel because this design from GM sucks. Hope this helps somebody. Dave
