Old 10-10-2006, 07:55 PM
car_guy_88 car_guy_88 is offline
96 GMC Jimmy thump under feet when turning
hey, i have a 1996 GMC Jimmy...just got it a few weeks ago, and im impressed..but one question, just within the past week or so, every time i turn a corner or have to stop very suddenly, i feel a thump under my feet...is this a tie rod issue?? hopefully something i can fix myself..any help would be appreciated..thanx
Old 10-11-2006, 03:18 AM
DelCoch's Avatar
DelCoch DelCoch is offline
Re: 96 GMC Jimmy thump under feet when turning
Is this a 4x4?
Old 10-11-2006, 02:54 PM
Yes, this is a 4X4 Jimmy SLE...and it just so you know, it makes the noise when i turn left and right
Old 10-11-2006, 03:00 PM
herkyhawki herkyhawki is offline
check your stabilizer bar bushings. bushing kits are cheap at auto part store.
Old 10-11-2006, 03:05 PM
ok sounds great, yea i didnt even think of that..but thanks for the advice, ill check those out as soon as i can....and just outta curiousity..how much are we talking for the bushings? cuz im a lil low on cash right now..so im just wondering how much they are
Old 10-12-2006, 09:08 AM
DelCoch's Avatar
They're like 10 bucks or less, for a set of 2 - take an old one with you to the parts store to make sure you get the right ones, as they come in different sizes.
Old 10-18-2006, 04:49 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
I have a follow-up question related to this thread. I recently replaced all the front bushings and stabilizer bar mounts with polyurethane and now I get the same thumping sound when I am turning and go over an uneven surface (i.e. one front wheel goes up or down relative to the other).
I know that I torqued everything to spec with the exception of the sway bar to a-arm bolt which said 132 in-lb (or 11 ft-lb). Since the nuts used are the nylon insert type lock nut, that can affect the torque applied, so to me it felt that they weren't tightened enough, but have no way of knowing for sure. Of course, no instructions for the sway bar bushings were included in the package. Any suggestions on how to correctly torque these bolts?
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 10-24-2006, 10:00 AM
jdmccright's Avatar
The RustBuster
Here's a follow-up to my own question. It turns out that the thumping I was hearing was caused by the end of the sway-bar link bolt getting caught up with the tie rod adjustment tube bolts. It was sticking up and was long enough (abt 1/2" above the nut top) plus the tube was positioned just right so that as I turned and the suspension flexed, they would interfere with each other, causing the thump sound as they got caught up and then released. I solved it (at least temporarily) by reinserting the sway-bar to control arm bolt with the threaded end pointing down. Not perfect for those needing ground clearance, but I'm not one of them. Still haven't found the right torque method...just tightened them down to reasonably firm with a box-end wrench.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 10-30-2006, 08:55 PM
trackrat trackrat is offline
I had the same problem. Make sure That your upper and lower ball joint bolts are tightened properly. I took it to 3 stealers(dealers) and they couldn't figure it out untill I took it to the dealership where I purchased the truck. They tightened them up at no charge and took care of my thumping problem.
It seems that the least looked at solution is never looked at at all.....
Hope this helps.
Old 10-30-2006, 10:15 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
http://www.automotiveforums.com/vbul...d.php?t=302656
Had the clunk as well, it is the hood.
Install these washers and it will go away.
DO NOT DO ANY FRONT END WORK UNTIL YOU DO THIS OR YOU WILL BE WASTING MONEY.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-01-2006, 10:52 AM
jdmccright's Avatar
The RustBuster
Well, the stuff I did replace did need to be and the interference was an issue as well. And I did use a torque wrench for all of the suspension bolts, though truthfully, the ball joint to arm bolt spec (~17 lb-ft?) was at the low end of my wrench's range (10-150 lb-ft). Hafta crawl back under & recheck....thanks for the tip.
But I do want to do this hood fix too...can you only get the washers from the dealer? Do you have a part number or service bulletin number to refer to (the link you gave was dead)? Thanks!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 11-01-2006, 01:50 PM
BlazerLT's Avatar
AF -Advisor
All the information is in that thread.
Old 11-13-2006, 11:07 AM
jdmccright's Avatar
The RustBuster
Well, I did the hood hinge fix but that wasn't it. i'm hearing two distinct types of clunks. One is when the suspension deflects from side to side (going over a dip at an angle) and the other is when I accelerate from a stop.
I've checked my torque wrench and found that it is low by 12-15 lb-ft from the dialed in number. That can mean all the suspension bolts are not tight enough. What a PITA....
The acceleration clunk I hear can be a bad u-joint somewhere or maybe a bad front CV joint (seems to be coming from the front left side) though I hear it even though I'm in 2wd mode...that or the front driveshaft u-joints. Will keep this updated!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 11-13-2006, 12:39 PM
BlazerLT's Avatar
AF -Advisor
1.) Swap bar end links and bushings. If you hear the clunk in the front when the truck sways, that is usually the problem.
2.) Acceleration clunk is the u-joint or the rear springs and spring bushings need to be sprayed down with oil so they don't catch.
Old 11-13-2006, 01:49 PM
jdmccright's Avatar
The RustBuster
Swap bar end links which way? Left to right? Flip them (head end on top versus head end on bottom)? As stated before, I flipped them head end up to prevent interference with the tie rods. They're both the same, so how will swapping them left/right improve it? Please clarify.
Also gonna look into getting a calibrated torque wrench and retorque all the suspension parts. I appreciate all the suggestions.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
