Old 10-10-2006, 04:27 PM
theliquorbucket theliquorbucket is offline
2000 z24 cavalier dim headlight
i have a 2000 z24 cavalier. the driver side headlight is very dim no matter if the low beams or hi's are on. my ay time running lights don't come on and when i start the car and out it in gear i can hear the relay click bout 6 times and the drl light flashes.i've changed bulbs and tryed seeking where the ground connects. any ideas???
Old 10-10-2006, 04:53 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
Re: 2000 z24 cavalier dim headlight
if its the DRL relay you're talking about clicking 6 times, i'd say thats definetely your problem, also, when that DRL light flashes, thats indicating theres a problem somewhere with your exterior lights
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 10-10-2006, 05:56 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Which side? Most GM cars have a fuse for each headlight. You should check the headlights fuses in the fuse/relay compartment under the hood. For some odd reason, the headlight will come on dim even though the fuse is blown.
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
