Old 10-10-2006, 03:42 PM
jjastap2 jjastap2 is offline
sonoma seems dead
I went out to start my 99 Sonoma and when I turned the key the dash lights flashed for a split second then went black after that nothing. I checked the battery with a volt meter and got 12.6 volts at the terminals but still nothing inside when I turn the key any suggestions?
Old 10-11-2006, 03:07 AM
DelCoch's Avatar
DelCoch DelCoch is offline
Re: sonoma seems dead
Check your fusses.
Old 10-11-2006, 07:47 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Battery is dead. Should be over 12.6volts.
Clean the battery terminals as well.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 10-11-2006, 02:29 PM
thanks for the suggestions but it turned out to be a bad connection on the positive battery cable even though on first inspection it seemed tight it wasn't making good contact.
