Old 10-10-2006, 11:39 AM
spyhunter99 spyhunter99 is offline
2 Piece VR4 Rotors
Anyone know of a company that makes stock sized vr4 rotors in a two piece design for the 2nd gen? I've been searching for a bit and haven't turned up too much unfortunately.
Old 10-10-2006, 02:46 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: 2 Piece VR4 Rotors
what exactly is a "2 piece" design? i can't think of a reason you wouldn't want your rotor to be anything other than 1 solid conglomerate of metal.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 10-10-2006, 04:23 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
2 piece rotors are actually a decent design. let me see if I can find a decent pic.
Old 10-10-2006, 05:29 PM
AutostradaVR4 AutostradaVR4 is offline
yea, that would be cool if you find one stealthee. im not familiar with them either. What exactly is the point? heat dissapation i assume?
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 10-10-2006, 05:56 PM
3kvr4's Avatar
3kvr4 3kvr4 is offline
Send a message via AIM to 3kvr4
Here is a link for 2 piece rotors it only tells about the good side of the two piece but i have no idea about the bad side if there is one. LLIINNKK
Old 10-10-2006, 07:33 PM
downside? there better not be one for $400 a piece! lol
Formerly BlinkRA182
Old 10-11-2006, 01:15 AM
Linebckr49's Avatar
interesting. i guess one benefit is that the hat (raised part where lug bolts go through) should never separate from the rotor. i've seen hats separate from the rotor on road course racing.
93 3000GT base
