Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 10-10-2006, 11:10 AM
Woowagon Woowagon is offline
Reap wiper motor - 1999 Passport
Anyone know if a motor from a '98 is the same? Ours has crapped out and I have two places nearby that each have motors from '98 for about $60.
Old 10-10-2006, 11:17 AM
Re: Reap wiper motor - 1999 Passport
Nevermind. I decided to not be such a lazy azs and checked the Autozone and Advance Auto sites. Cardone markets a reman motor for $80ish and the PN is the same for a '98 or '99. By the way, it has a "limited lifetime" warranty. I think I'll go that route unless I can get either of the used ones for around $40.
Old 10-10-2006, 12:28 PM
rodeo4me rodeo4me is offline
Make sure you also check relays for rear wipers. They can go bad and it make rear wipers inoperable.
Old 10-10-2006, 07:52 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
I would bet its the relay too.
When my rear one stopped working I thought it was the motor until I started testing the relays to replace them. Relays are much cheaper then the motor, unless you buy a new box instead of doing a DIY repair.
http://forum.planetisuzoo.com/viewtopic.php?t=5608
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 10-11-2006, 11:55 AM
After much hunting, I finally found the relay box. I grounded my test light and proceeded to test the relay (horn works!). The rear wiper did not actuate at first, then it did, then it quit. I am still not sure if the realy is the culprit. I had to have my wife come and listen at the tailgate. When we opened the gate is when the motor started working (wiper arm is off). I thought maybe a braken wire at the gate hinge. But then it quit again with the door still open. ???
Edit:
Also, after getting the relay and motor to "work" with the test light, I tried using the dash switch and that did not work.
Old 10-28-2006, 05:34 PM
Gizmo, thanks for the excellent write-up. I ordered the relays and just finished installing one (two kept as spares). Rear wiper works just like before. I posted in the other forum about my experience. There are a few things different with my circuit board and relay locations on the board. But, the process is the same as you said.
Old 10-28-2006, 10:35 PM
Gizmo42's Avatar
Glad everything is working now. Relays are so much cheaper then replacing a good wiper motor LOL.
--Dave
Rear No-Slip Locker
Old 12-27-2006, 08:39 AM
madison rodeo madison rodeo is offline
I have a 97 rodeo and now my rear wiper does not work at all. I checked the fuse and it was burnt out, so I replaced it. It still does not work. Where do you find the relay for the rear wiper. And where do you purchase a relay at?
Old 12-27-2006, 01:48 PM
trooperbc's Avatar
trooperbc trooperbc is offline
click on the link in Post#4 of the following thread, read it, and follow it...
http://www.automotiveforums.com/vbul...d.php?t=630190
can 't see how you'd want any more info than gizmo et al have already given up there. . .
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
