Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 10-10-2006, 08:41 AM
jrmlwalker jrmlwalker is offline
Question Brake Question
I have a 2004 Impala.Took both front brake disk off to have turned.The part of the caliper that holds the pads , it's removable from the main caliper , are mixed together. I thought right could only go on right and left on left , but now I am ready to put back together and see that either can go on either side.Parts are marked on both ends , but I need some help to get them on the correct side. Thanks
Old 10-10-2006, 09:12 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Brake Question
GM usually casts an L (drivers side) and R (pass side) in their calipers. The brackets that bolt to the spindle are interchangeable (GM #18029829), but the hydraulic portion are side specific. If you didn't disconnect the brake line and completely remove the hydraulic part from the car, it doesn't matter which side you put the brackets on.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 10-13-2006, 08:45 PM
rhandwor rhandwor is offline
Re: Brake Question
This is for your information only as Rick would know this. If your replacing calipers and put them on the wrong wheel. The bleed screw would be on the bottom and you can't bleed the system.
