Go Back   Automotive Forums Car Chat > Mercedes-Benz > E-Class
Old 10-10-2006, 01:55 AM
Bratzo Bratzo is offline
Unhappy 93 - 300E help
The Low engine cooland level warning lamp is on, i check the cooland level and is ok there is no liks. Temp is normal, no idea why the lamp is on ? any ideas please help.
Thanks
Old 10-25-2006, 10:35 PM
arlingtoncountyred arlingtoncountyred is offline
Re: 93 - 300E help
Defective coolant level sensor is the most likely cause, it is located in the coolant surge tank.
Old 01-09-2007, 09:50 PM
seafishy seafishy is offline
Re: 93 - 300E help
Question. is the surge tank the plastic tank you pour the coolant into?
Im having the same problem on my 1990 300E. The radiator light comes on then goes off and sometimes flickers....
Once I have located the surge tank what does the sensor look like. Can I do the replacement myself without too many tools...In other words will this be an easy replacement?
Thanks
Old 01-14-2007, 12:19 PM
Re: 93 - 300E help
Since I'm not a mechanic I took my car to my MB mechanic and he said it was the sensor and the fill tank had to be replaced because of a small leak along with the hose..
Old 01-14-2007, 02:48 PM
benztech82 benztech82 is offline
Re: 93 - 300E help
the surge tank is the tank on the passenger side of the car if I'm not mistaking on that model. the sensor can be replaced but you'll need a set of snap ring pliers that can be purchased at any auto parts store. they will need to be for external snap rings. if you are looking from the front of the car the sensor will be located in the lower right hand side of the reservoir or on the bottom front and have a small two wire plug going into it. sometimes these plugs become corroded so make sure to check and/or clean yours if you decide to do this. replacement is simple. Unplug the sensor carefully, the plastic housing will break. Completely remove the snap ring. pull out the old sensor and drain the coolant out into something. make sure the old o-ring came out with it. slide the new sensor in exactly like the old one came out. reinstall the snap ring and plug it back in. now top off the coolant and you should be good to go. hope this helps.
