Old 10-10-2006, 01:00 AM
Hunter1 Hunter1 is offline
No Heat!!??
Ok after hours of reading posts, i'm stuck. I have a 98 blazer lt auto climate control. My problem is I have no heat. The operating temp of the truck is only about 150 Degrees (I can't help but feel the two are related). I have flushed the entire cooling system. The rad. is new (unrelated repair). The fuses are good. I can hear the blender door opening and closing as it should. thanks in advance for any help...
Hunter
Old 10-10-2006, 09:25 AM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Re: No Heat!!??
Sounds like you have a stuck open thermostat, should be replaced with one that is 195 dgrees I believe. Basically the coolant is flowing freely around the engine, consider yourself lucky, if the thermostat was stuck closed you would have plenty of heat! And a possible blown engine!
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 10-10-2006, 07:28 PM
Re: No Heat!!??
Thanks I will try that!
Old 10-13-2006, 09:16 PM
Re: No Heat!!??
I changed the thermostat. temp back up to 195 but I still don't have any heat from the heater. are there any other suggestions?
thanks
Hunter
Old 10-14-2006, 10:36 AM
alblogg's Avatar
alblogg alblogg is offline
Re: No Heat!!??
When you said you flushed the entire cooling system did you unhook your heater hoses from your heater core and back flush it? If not this might be your prob. or it has air trapped in it and needs burped out.
'99 Blazer LT Loaded, K&N Filter, Pioneer Super
Tuner,Viper
'98 Pontiac Grand Prix GT, 3.8
'88 K1500 Cheyenne, 5.0, stock, bought new
'86 Nissan 720 Trash Truck
'69 C/10 step side, 307, all original, second owner, in process of restore.
The person who says it cannot be done should not interrurt the person doing it.
Share your knowledge. It is a way to achieve immortality.
Allen- Paintman
Wrenchtwister
Broompusher
Old 10-14-2006, 11:25 AM
IceFire's Avatar
IceFire IceFire is offline
Wink Re: No Heat!!??
I had the same issue with mine. What the problem was is the hose that goes from the heater box to the intake manifold where the metal pipe connects to the intake has a smaller diameter hole and the end of the pipe begins to wash away. Small pcs gradually wear off and end up getting stuck into the end of this pipe. What you need to do is disconnect the pipe from the intake, clean the end of it and reinstall it.
~^^~IceFire~^^~
Old 10-28-2006, 09:38 AM
Re: No Heat!!??
I did a back flush on the heater core, but that didn't seem to help. I am inthe dash right now. I have two vacumm hoses (one black the other orange) the black one controls the vent location but I can't figure out what the orange one controls (at least from the controls on the dash) It is attached to a vent that if I onpen it manually a rush of air leaves from inside the cab. The truck has auto temp controls which have never seemed to work right(ie outside temp is 30 and the a/c kicks on (WTF?!?!?)) The other problem is that I can't seem to find the blend motor. But I guess I will try to get back to it. Just let me know what you guys think. I will be working on it this weekend since I don't have to work.
Thanks
Hunter
Old 11-01-2006, 07:36 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: No Heat!!??
Thanks
Hunter
The one that pulls air from inside the cab is the air recirculation door...during AC, it pulls cool air out and runs it past the AC evaporator instead of grabbing hot air from the outside. Cools and dries the cab air much faster and reduces the amount of condensation to deal with.
