Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 10-09-2006, 11:45 PM
coldday coldday is offline
piston condition
timing belt broke on my 4cyl rodeo 1999
i'm posting photos from the worst pison and wonder if it is passable? thanks.
here is a picture too, of all 4 from top;
http://www.sierranature.com/pistons.jpg
Old 10-10-2006, 12:11 AM
JustSayGo JustSayGo is offline
Send a message via AIM to JustSayGo Send a message via Skype™ to JustSayGo
Re: piston condition
Smooth any sharp edges a little with a file, knife, or powered Scotch-Brite disc. You won't have a problem. I don't see enough damage to squeeze a ring land and cause the top ring to stick. There is no benefit in working on the pistons until they look new. Now your pistons have tiny valve reliefs just like many new pistons.
Old 10-10-2006, 01:03 AM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
I agree, clean it up some and try it. If it works ok and lasts then great. If not you end up with a rebuild or new engine anyways and havent really lost much except time.
Just dont put it together and try to pawn it off on someone. Not saying you would but some ppl do.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 10-10-2006, 07:14 AM
redbug redbug is offline
Hello,
This piston is not the concern here... It's the gouge in the cylinder wall (top picture) that I would be worried about.. The sleeve needs to be replaced (if there is one). The rings will not hold compression at the gouge... Hot gases will eventually blow by the rings and fry the oil up on they cylinder wall, no lubrication, friction, ouch.... If the gouge is as low as the oil ring you will be sucking up oil into the chamber on the intake stroke.... All in all, not a good sign....
Old 10-10-2006, 09:57 AM
2000izusu 2000izusu is offline
yeah i saw that to but thought it was a piece of carbon hanging down (due to the shadow on the left). well coldday is it a gouge or carbon?
2006 liberty 3.7 6speed manual
1999 cherokee classic 4.0L
1991 wrangler yj 2.5L
2001 caravan 3.3 auto
1995&1992&1994 camry 2.2L SOLD
1991 silverado 1500 SOLD
2000 rodeo SOLD
Old 10-10-2006, 11:53 AM
rodeo02 rodeo02 is offline
You could try to clean up the piston tops and cylinder bore. Hard to say how reliable it will be though. I've seen crashed pistons crack when put back into use. They are just thin aluminum.
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 10-10-2006, 01:58 PM
thanks for all the input.
that's a carbon flake hanging down there, so my only concern was piston strength. I'm planning on ordering a rebuilt head ($425) and putting that on, as at least 1/2 the valves are bent on mine and an exhaust manifold stud is gone (was gone on it's own at some point... second new exh. manifold put on this car...) machine shop wants 372 labor and 7-15/valve so figured 425 was better. have to remove the exhaust cam to remove the head bolts on that side though, pita...
figured i'd just clean out the loose stuff/coolant drips and start ordering gaskets and tensioner/idler pullies which i want to replace.
what about oil pump? worth thinking about replacing? 137k.
thanks.
Old 10-14-2006, 11:31 PM
Oil pump gears are just gears that pump oil. The will have little if any wear ever... unless hard metal goes through the pick-up screen to get to the gears. Replace the Oil pressure regulator spring. The spring controls the oil pressure and every spring made will break if it is flexed enough times.
Old 10-15-2006, 11:49 AM
surferfletch surferfletch is offline
I don't know if I could drive the vehicle knowing that a couple of the pistons were damaged like that. How long would you expect before that hot spot caused the piston to crack?
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2
1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs
1996 VW Jetta GLS 2.0L 5 spd
Old 10-16-2006, 12:18 AM
As long as any other piston that was built with valve reliefs. There won't be a hot spot and the piston will not crack because it has dents hammered into it. The sky will not fall. Maybe you have already driven more miles than you know... but never knew.
