Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 10-09-2006, 09:57 PM
acidcrashdburnd's Avatar
acidcrashdburnd acidcrashdburnd is offline
Send a message via AIM to acidcrashdburnd
TPS problems AGAIN!!!!!!!! i think?
i was coming home from work pushin around 65 the ses light came on and the car booooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooged down it seemed like it wouldnt go any faster the light goes off car sputters then resumes normal operation but it's still slowww im gona have the codes pulled tomorrow i hope its not the last time i changed the tps it was a PITA!!!!
1993 Olds 88 112k and counting 81 mile a day daily driver.
2005 Grand Prix 47k weekend car.
Old 10-10-2006, 02:45 AM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Re: TPS problems AGAIN!!!!!!!! i think?
You may want to look into checking your Ignition Control Module and your coils too. The ICM typically gets flakey in the 50-65mph range. Really common though.
And this won't throw a code either...but another code may have tripped in response.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 10-11-2006, 02:15 PM
how would i go about testing that stuff and could it be bad spark wires ?
Old 10-11-2006, 03:17 PM
maxwedge maxwedge is offline
A990 racer
And the codes are/were? Year of car?
Old 10-11-2006, 05:03 PM
93 with 54234 on it i havent got the codes yet my guy cant find the card for his reader that works with my car
Old 10-11-2006, 07:14 PM
Alibi's Avatar
This a link to tell you what the ICM/Coils are:
http://bellsouthpwp.net/p/a/padgett46/coils.htm
Assuming the ICM is at fault, it very rarely throws a code (usually for a different system). As for testing the ICM, you can remove it and have it tested at an Autozone or O'reily (I think). Just have them test it several times so that it can heat up just a tad bit.
As for the coils, you can test them by:
1. Get your car to a really dark road/garaged
2. Start 'er up
3. Use a pair of INSULATED pliars and pull the plug boots off each coil terminal. If no spark or an erratic spark, then that is your problem.
You can also test your plug wires at the same time. Use a bottle that can mist water and very lightly spray the wires. If you see little blue sparks or arcs, then you need new wires. If your wires havne't been replaced in 80k or so miles, replace both plugs (AC delcos only!) and wires (spend at least $20) at the same time.
Just noticed, your motor has 54k on it. I'd say the plug wires are still ok, but have you checked/cleaned for corrosion on the boots and plugs? That might cause a bit of misfire.
-Eric
Old 10-11-2006, 10:00 PM
2. Start 'er up
i like how you emphasized insulated im just gona go pick up some new wires when i get the $$$ being i have 50 cents right now and were will the spark come from the little things on the coil pack or the wire?
UPDATE i found three cents under my desk so i have 53 cents now
Old 10-12-2006, 12:08 AM
Alibi's Avatar
Having the ICM tested is free
That way, you can keep your 53 cents in your piggy bank...or get a quarter of a gallon of gas...
-Eric
Old 10-13-2006, 03:15 AM
well it seems it was just the MAF!!! i cleaned it with brake cleaner and i also noticed the wire and the lil prongs were corroded so i took a wire brush to it. the car is back to normal! YAY! :-D
