Been awhile since i worked on my sons tracker trying to remember if it has a clutch fluid resevor pardon the misspelling he went to drive it the other day and the clutch went to the floor and stayed[email protected]
Re: 1994 tracker clutch
Had the same thing happen with my 96 Tracker. Check the clutch cable, you'll most likely find it broken in two.
Keep in mind to check the clutch. I had the same thing happen to my 94, so I replaced the cable. Then it still wasnt working, that lead me to the clutch. I would check the clutch first, remove the little metal plate that is covering the front of the tranny. Or if your lucky there is a rubber stop in the bell housing. If you have the stop then pull that and feel around, and if you feel metal like substance its your clutch.
