| 240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all. |
Supercharged Z32
I am putting together a supercharger system for my Z32 N/A. I am looking at a paxton procharger or vortec unit. When the supercharger compresses the air does it heat up as much as a turbo does? If so could I place an intercooler or aftercooler system behind the front bumper. I am thinkin about running 6psi with (already installed-->) tubular heat wrapped headers, greddy cat back, fidanza lightweight flywheel, stage 2 clutch. With dyno tuning added after I put together this supercharger system would 6psi on stock internals be safe? Now I know that guessing horsepower is a shot in the dark but with proper tuning what kinda *rough* numbers could I be looking at here? Thanks everyone.
Re: Supercharged Z32
why?
ZedEx Crew Member #61988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc. blown turbo, under construction.. gt35 coming. |
Thats an ass load of work for what a mildly modded TT will make.
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo ![]() Warning: Objects in mirror aren't as fast as they thought they were. |
I don't know superchargers, but I'm just curious... those aren't centrifigul (sp?) type s/c's right? What kind are they...
Georgey on the subject of midget beastiality pornos Quote:
R.I.P Andy, you will be missed by all. |
make sure you know what you are getting yourself into. there is alot of custom work involved. custom upper plenum would be invloved for a standard roots type blower. i personally think that dropping the AC compressor and replacing that area with a centrifugal type supercharger would be the easiest and a well designed intake tract that will evenly split the air in 2 equal flows to feed each stock throttle body. even for this, it will be hard to design and some kind of intract flow device would almost need to be designed to equalize the flow but it would save the money involved in designing a good upper plenum that will still fit the stock hood. all in all, your looking at a lot of money and effort for not that much of a gain. by the time you are done you could have probably had a Twin Turbo at 400rwhp. i see this setup at 6psi dynoing 250rwhp and keep in mind this will need to be tuned regularly. any change in ambient temperature will dramatically heighten your chance of detonation will lead to the destruction of your hard work.
ZedEx Crew Member #4
