Old 10-09-2006, 03:37 PM
gserve gserve is offline
power window problem
96 Cavalier passenger side power window is not working. How do you remove the switch in the console to check it? Also if its the motor how do you remove the door panel. Thanks
Old 10-09-2006, 06:45 PM
Lances133's Avatar
Lances133 Lances133 is offline
Send a message via AIM to Lances133
Re: power window problem
Well, about the door panel, all there is to it are a couple screws around the edge of it and then clips so unscrew them all and pull it off.
Old 10-10-2006, 11:43 AM
my99cavy's Avatar
my99cavy my99cavy is offline
Send a message via AIM to my99cavy Send a message via MSN to my99cavy
Well to remove the switch in the center console all you have to do it take a flatblade screw driver and pry it up, once its out just unclip the harness and you can take the switch all the way out.
Door Panels
The door panels like lance said are held on with 4 or 5 screws around the bottom or the panel and 2 srcews by the handle, remove all them and then pull on it to release the clips.
Fig. 6: Remove the retaining screw for the upper trim panel and ...
Fig. 7: ... remove the panel from the door
Fig. 8: The door panel is held by six retaining screws, two under the door handle and four along the bottom. Remove the four along the bottom and ...
Fig. 9: ... remove the two screws located under the door panel inside handle-front door
Fig. 10: The door panel is retained by eight retaining clips located in the positions shown-front door
Fig. 11: The retaining clips can be released by carefully pulling the door panel from the door assembly
Fig. 12: When all the retaining clips are disengaged, remove the door panel
Window regulator and motor
once you get that off there is a metal panel though which the motor is behind so to get to the motor you will have to remove that also.
Fig. 1: Remove the regulator retaining bolts
Fig. 2: Remove the regulator retaining rivets
  1. Remove the door panel and the water deflector.
  2. Remove the door glass (window).
  3. On front door regulators only, remove the regulator retaining bolts.
  4. Using a 3/16 in. (5mm) drill bit, drill out the regulator attaching rivets.
  5. Move the regulator rearward and disconnect the wiring harness from the motor, if so equipped. Disengage the roller on the regulator lift arm from the glass sash channel.
  6. Remove the regulator and motor through the rear access hole.
Old 10-10-2006, 12:06 PM
Lances133's Avatar
....show off
Old 10-10-2006, 12:43 PM
my99cavy's Avatar
Originally Posted by Lances133
....show off
what can I say..
Old 10-10-2006, 06:29 PM
Thanks for the replies.And thanks my99cavi for the walk through very informative.
Old 10-10-2006, 06:31 PM
my99cavy's Avatar
No problem man any other questions feel free to ask .
Old 10-10-2006, 10:39 PM
Crazzzyj's Avatar
Crazzzyj Crazzzyj is offline
Send a message via AIM to Crazzzyj Send a message via MSN to Crazzzyj Send a message via Yahoo to Crazzzyj
I wonder if he searched the forums for this problem before making the post... But yes, that post was very 'illustrative'.
~Crazzzyj
Modifications
Lightning Audio Amp and 2x 12'' Subs.
Black Altezza (Euro) Taillights.
Black JDM Headlights w/ Black Corner Lenses.
RVinyl Dash Kit.
Pioneer CD Player w/ Rear Deck Speakers.
Raceway Decal.
Apexi Dragger Muffler.
''16 Motegi Riax Rims Glossy Black.
http://www.cardomain.com/ride/2182327
Old 10-10-2006, 10:46 PM
my99cavy's Avatar
~Crazzzyj
No I really doubt he searched before posting since half the people on here dont lol and what is it a bad thing that I post all this info?? lol just trying to help out thats all
Old 10-11-2006, 05:57 AM
Can you help me with my airbag/seatbelt lights staying on problem?
Old 10-11-2006, 10:47 AM
my99cavy's Avatar
If the airbag light is staying on then thats means that something is wrong with that system. I'm not really sure what to do with that though since I have never delt with it sorry.
Old 10-11-2006, 04:02 PM
Lances133's Avatar
Check the airbag fuse on the driver's side of the dash and see if it's blown, if not, keep it out and take off the cover on the steering wheel and check for any bad connections or anything out of the ordinary, it could also have something to do with the passenger side air bag, to check those you have to remove the top vinyl part of the dash. Or like MT said, get it scanned by an SIR/scanner and scan the code and go from there.
