Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 10-09-2006, 02:58 PM
chevboy chevboy is offline
New Car New Problems
Hey guys new to the nissan forum i used to own a cavalier z24 and recently like two days ago picked up an 03 nissan sentra ser spec v iam taking it back to the dealer for service but i am unsure whats wrong with it it seems to never want to start it will turn and turn before it finally goes but its intermittent idont understand that and yesterday the tach stopped working then kicked in again and iam really pissed cause this was not a discount car it was a little more then the other ones i looked at but it had all the options offered and resoable clicks now iam having these problems any ideas thanks for any help
Old 10-09-2006, 03:31 PM
ProZach626's Avatar
ProZach626 ProZach626 is offline
Send a message via AIM to ProZach626
Re: New Car New Problems
I would bet money that it's the fuel pump. I had the same EXACT problem on my 03 spec. Thankfully it was covered under my warranty. On the subject of problems... I don't know if you have researched your car at all yet, but there are a few more issues with the spec v to adress:
1st thing you need to do is crack open your intake manifold. There are butterfly screws on the inside that are sooo notorious for being sucked up into engine and ruining it instantly. Remove the screws, locktite them, and put them back in.
2nd thing you need to do is order a balance shaft assembly removal kit. The balance shaft spins at twice the speed of your engine to eliminate minor vibrations. When taken out, people say there is pretty much no difference in the feel of the car other than the 8 hp gain . I've been told that the bearing can break apart and get sucked into your engine.
3rd thing that needs to be taken care of is the pre-cat. The header has a precatalytic converter on it. The insides love to burn up and fly into your engine. I had mine replaced at 75k miles because it was also under warranty. You need to pick up a catless header and instal it on your car. Unfortunately they cost 3-4 hundred dollars. Save for a hotshot which is around 400+ dollars. It gives you the best gains. 16-20whp I believe.
Other than that... get a CIA because the sound by istelf is just awesome.
Anyway... your spec v reguardless of the problems is a hell of a lot better than your old cavi. Have fun with it.
Old 10-09-2006, 03:33 PM
ProZach626's Avatar
I do have another idea... Punctuation in your posts :P
Old 10-11-2006, 03:34 PM
slideways...'s Avatar
slideways... slideways... is offline
tach signal is read off the ignition timing from the cam position sensor thru the ECU, so its either wiring, the guage itself, or the sensor or ECU.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 10-15-2006, 10:18 PM
sincspecv sincspecv is offline
sounds to me like your crankshaft position sensor. did it throw on a service engine soon light? your tach is ran off of your crankshaft position sensor and it will have trouble starting like that (mine has that problem as we speak). there was just a recall in august or something like that for that sensor. take i to the dealer and ask if the recall was done. i'm not sure what the recall entails, because i haven't had time to look into it, but that is most likely the problem.
