Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 10-09-2006, 02:52 PM
mr moose mr moose is offline
96 suburban rear end??????????
does any one know if a 99 tahoe rear end is the same width as my 96 suburban and will it work as long as the ratio is the same? thanks. mark.
Old 10-09-2006, 02:57 PM
maxwedge maxwedge is offline
A990 racer
Re: 96 suburban rear end??????????
Check with a salvage yard for interchangeability.
Old 10-09-2006, 05:01 PM
idmetro idmetro is offline
Check http://car-part.com/index.htm I believe it uses an interchange when searching. In this case it appears the Suburban/Yukon/Tahoe might be interchangeable. Obviously you will want to check in person (or at least compare measurements with someone standing at the differential) but seems like a good possibility.
Old 10-16-2006, 08:11 AM
thanks for the help.
