Old 10-09-2006, 02:49 PM
w_hodel's Avatar
w_hodel w_hodel is offline
Send a message via AIM to w_hodel Send a message via MSN to w_hodel Send a message via Yahoo to w_hodel
Unhappy Another Rough Idle Thread
Hey guys, I searched the site hopefully I didn't overlook a thread with the same exact problem. I just rebuilt the engine in my 91 Stealth R/T NA and I start her up and it sounds like my timing is HORRIBLE, and then she stalls. I put in Stage II cams, and a forged crank would that matter for my timing? I messed with the CAS and idle adjustments and such but to no avail. Any ideas?? It starts and wants to die, if I pump the gas it will rev high and then start to die again. I have tried adjust the Idle Screw that is recessed into the throttle body (not the fixed screw). I have checked my vacuum lines, it is driving me crazy. Also the honeycomb type stuff (don't know the name) inside my Mass Air Flow Sensor is gutted, it was bent up so I finished the job, but it ran fine after I did that, but is that stuff useful or unimportant? any ideas would help. Thanks
1991 Dodge Stealth R/T NA ATX
Dual Exaust w/12" Glass Packs
3SX Downpipe
Magnaflow High Flow Cat
Alpine Deck, Alpine Speakers
2 - JL W3 10" Subs w/JL 500w Amp
PS2, 7" Flip Down Screen
6-Disc CD Changer
Sound Dampening Spray all throughtout Interior (Huge Difference!)
Sunroof (installed soon)
3SX Aluminum Crank Pulley, 3rd Gen Lifters
Aluminum Intake Pipe w/Matrix Air Filter
2002 Ford Ranger XLT Ext Cab 3.0 V6
Old 10-09-2006, 03:34 PM
Ralliart 3000gt's Avatar
Ralliart 3000gt Ralliart 3000gt is offline
Re: Another Rough Idle Thread
Stepper motor, ECU, Spark plugs, Timing??? I would try cleaning/replacing the stepper motor first, then check the ecu for any leaks, etc....................
Old 10-10-2006, 02:06 PM
w_hodel's Avatar
Where can I find info on cleaning the stepper motor, do you have a link? Also, do I have to "realign" it or anything, never messed with the stepper motor before
3SX Downpipe
6-Disc CD Changer
Old 10-10-2006, 02:49 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
stepper motor
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 10-10-2006, 02:55 PM
w_hodel's Avatar
Thanks Linebckr I appriciate it
Are you talking about checking the capacitors in the ECU for leaks??
3SX Downpipe
6-Disc CD Changer
Old 10-10-2006, 03:21 PM
Linebckr49's Avatar
yes, he's talking about leaking capacitors.
93 3000GT base
Old 10-12-2006, 10:53 AM
Igovert500's Avatar
blue + red light magnet
Have you checked the timing? Are you getting any Check engine lights? Gutted MAS are fickle. Some people have no problems with them, others have major idling issues with them...so borrowing and swapping in a non-gutted one wouldn't hurt (DSMs have identical MAS just fyi) just to see if that is the problem. IAC as mentioned above, ecu caps...possibly. Pressure test the intake, a blown-off or cracked intercooler pipe could cause that. Just recheck the obvious stuff.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
