Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 10-09-2006, 10:52 AM
pcoleman pcoleman is offline
2001 explorer transfer case vent tube
Where does the other end of the transfer case vent tube hook to?
Old 10-09-2006, 10:04 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 2001 explorer transfer case vent tube
Which end are you referring to, the end that connects to the transfer case or the end that vents to the atmosphere?
-Rod
Old 10-10-2006, 10:56 PM
[quote=shorod]Which end are you referring to, the end that connects to the transfer case or the end that vents to the atmosphere?
-Rod[Should transmission fluid be coming out of this hose?/quote]
Old 10-10-2006, 11:02 PM
Should fluid be coming out of this vent hose?
Old 10-11-2006, 12:13 PM
shorod's Avatar
SHO No Mo
The only time I would expect fluid to come out of this hose is if the transfer case is over full. I'm not sure if the transfer case uses gear oil or transmission fluid. Is your Explorer full-time AWD or selectable 4WD?
-Rod
