Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 10-09-2006, 10:03 AM
Rusty280Z Rusty280Z is offline
Send a message via Yahoo to Rusty280Z
92 Cutlass Supreme heater hose question?
92 Supreme SL, 3.4 DOHC I have a fixture located on top of the heater hose metal housing prior to the engine block that looks like a grease fixture. I cannot find this item in my Chilton's manual. I did notice a very small amount of coolant at the bottom of the fitting. Is this a grease fixture? Any reponse would be appreciated, Russ
Old 12-24-2006, 02:38 AM
Roudy4x4 Roudy4x4 is offline
Re: 92 Cutlass Supreme heater hose question?
Im not 100% sure, with your car, but those fittings are usually for releasing air from the system. It kinda looks like a grease fitting, or a brake bleader screw... To know for sure, start your car, and let it warm up, once its warn, loosen that fitting just a little, and steam/air chould come out, your soposed to crack it opened, untill all the air comes out, then tighten it...
Hope this helps
Old 12-25-2006, 02:20 AM
theragtopguy theragtopguy is offline
Roudy4x4 is correct, that is an air bleeder screw.
