Old 10-09-2006, 09:19 AM
pitteach pitteach is offline
dash lights flashing
Driving home last night, my dash lights started to go from dim to bright repeatedly. Is it possible that a weak battery could cause this? I'm pretty sure that the battery is original from 2000 and I have been expecting to replace it anyway. I have heard about interior lights and gauges having gremlins, but I am hoping that this is just the battery on its way out. Otherwise, the van starts and runs ok. Any thoughts would be appreciated. Thanks.
Old 10-15-2006, 08:15 PM
rivguy rivguy is offline
Send a message via Yahoo to rivguy
Re: dash lights flashing
is it the back lighting only? have had bad dimmers on the vans - try to roll the dimmer very fast all the way a couple times and then leave it in a different lovation than you had it - if it is the problem they should return to normal
-=-=-DANE-=-=-
Old 12-25-2006, 10:39 PM
mertze mertze is offline
I was hoping to find someone with the same problem as mine on my '96 Windstar which is that my dash lights, noticeably my clock, repeatedly cycles from dim to bright which is because an outside light (parking lights) are turning on and off. The interior light should go dim when the outside lights are on, as it is normally nightime and this is so your eyes will not be overwhelmed by the brightness of the clock light. I can hear a relay clicking someplace under the dash which is probably turning on the parking lights. This will continue for some time even after shutting off the ignition switch. Any ideas?
Old 12-25-2006, 11:32 PM
I had hoped to find someone with a similar problem as I have. My dash lights, noticeably the clock light, cycles from dim to bright repeatedly. This is because an outside light (parking lights) are cycling on and off. The interior lights should go dim during nightime so as not to overwhelm your eyes by the brightness of the interior display. I can hear a relay clicking under the dash during this time and it continues for a while even after I turn off the ignition switch. This occurs intermittantly, but for a rather long period of time. Are there any ideas on what is happening?
