Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 10-09-2006, 08:45 AM
skier-24 skier-24 is offline
Timing Belt
Hello All,
The owner's manual says change timing belt at 60,000 miles. How long have you gone before changing the timing belt. Surely they last longer than that.
Old 10-09-2006, 12:24 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
Re: Timing Belt
the thing with timing belts is that they may or may not last longer, but that is the best time to change it simply because, pushing cars to their limits and not doing maintenance can result in a failed timing belt, and then you have no engine.
now... you may be fine for a while, but if you simply do not change it, you are screwed.
maintenance first, then modifications.
Don't act like you don't love it.
503/2000
Old 10-09-2006, 12:58 PM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Re: Timing Belt
I was talking to my mechanic (toyota certified) and was asking him about the timing belt because I wasnt sure when it had been changed (if ever...ive got 103000 miles now). I went in at 100K you check and he said that he has yet to see a 6g72 motor that had a bad belt at 80-100K miles and told me to just get it done at 110-115K miles. I am not saying this is true in all cases, but my guy see's a lot of new sebrings/stratus's with the same motor and he says they all look good, and the belt is really strong for this motor. Just my 2 cents.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
