Go Back   Automotive Forums Car Chat > Ford > Tempo | Topaz
Old 10-09-2006, 09:31 AM
ashick ashick is offline
94 Tempo mystery switch?
I bought a 94 Tempo for my 17y/o son this weekend. That same day the car would not start. I asked the guy I bought it from and he said it did this one time last month. When this happens what you have to do is while turning the key in the ignition you have to push in the shifter button and move the shifter around the "P" until you hear contact in the motor. I also asked a friend who said it could be a switch of some kind. Any ideas? and would be a cheap fix or expensive fix?
Old 10-09-2006, 09:48 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 94 Tempo mystery switch?
Welcome to your first post on AF.
Your problem may be a neutral saftey switch or just a adjustment on it.
Check your parts place for price and pick up a repair manual.
A repair manual should show you how to adjust/check/replace the switch led you threw the repair.
Good luck MT
MT
Old 11-22-2006, 01:49 PM
jsweeter jsweeter is offline
When this happens again put the car's transmission in neutral and see if it will start if so this is a neutral safety switch problem. Mine has been doing it for years. I just put it in neutral start it and put it back in park. I have an 89
Old 10-14-2015, 11:56 AM
V8FordTempo V8FordTempo is offline
I have replaced many Neutral Safety switches... easy fix, and yes that is your problem...
