Old 10-08-2006, 08:06 PM
theduetch theduetch is offline
Probably A stupid question...
I have just bought 2 15" Kicker L7s (4 Ohm) and I have a ZX 1500.1 amp which is 2 ohm. I've always heard that it's bad to mix a two ohm amp with 4 ohm speakers but lately I've been hearing that it doesn't matter. Do I need to replace the speakers with 2 ohm L7s or is the system fine as is? Any help at all is appreciated. Thank You.
Old 10-08-2006, 08:25 PM
PlayStation3 PlayStation3 is offline
Re: Probably A stupid question...
you need to buy new subs or a new amp because either way you wire it the amp will either blow from over heating ( to low impendence) or would give off crap output becuase of too high impence. thats why you don't want to just go to an audio store and buy them you want to research them
Old 10-08-2006, 08:38 PM
Alright thanks. You wouldn't happen to know of a website where I can buy some 2 ohm L7s for cheap would you?
Old 10-08-2006, 11:17 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
You dont need a new amp or new subs. the amp can handle a 2 ohm load which is perfect for your setup. Wiring them parellel like this
http://www.cardomain.com/shop/woofer...svc&x=160&y=12
Will net a 2 ohm load. Most amps can handle between 2-8 ohms with the exception of the 1ohm and lower stable amps. But there are some that wont handle 2 ohms in certain setups. Your setup will be fine if installed correctly.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 10-09-2006, 06:19 AM
those are single voice coil subs in the pic for duel voice coils like the l7s are. and that would create a 1 ohm load which equals one fryed amp if it is not 1 ohm stable and also try ebay for l7s
Old 10-09-2006, 04:03 PM
He didnt say whether it was dual or single just 4ohm. Well then wire them in series and you will hav 4 ohm. Just making the amp produce closer to 750 rms to the subs which will be 325 to each. Which means half the rms power to each sub. Which wont be as loud but it will work.
You dont need rms power going to a sub.
Cardomain
