Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 10-08-2006, 07:42 PM
crapeyes crapeyes is offline
Thumbs up SOLVED my misfire, engine light issue
After replacing fuel filter,spark plugs (2x's), 1 coil, and MAS she (2001 3.9) still was very sick(ning).......but then took out the EGR valve and cleaning it COMPLETELY, and then putting 2.3 gallons of 105 octane~SHE IS RUNNING STRONG AND LIKE SHE USED TO...FAST !!!!!!!! Maybe Rob out there can assist me on airbag light issue....code when starting goes 3-2-3-2 and yes there is a long pause in the middle of those #'s. Any help will genuinely be appreciated
Old 10-08-2006, 09:20 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: SOLVED my misfire, engine light issue
A code 32 Lamp Fault Code indicates driver air bag circuit resistance high. This can be caused by dirty or poor connections, but quite often indicates a faulty clockspring in the steering column. The clockspring has been a common issue on the LS and a quick search of this forum for "clockspring" should give you lots of pointers and tips if you choose to change the item yourself.
-Rod
Old 11-06-2006, 12:17 PM
2_Late_I_Won 2_Late_I_Won is offline
Mine gave me the same code it was a clockspring
